Forum Does anyone have experience with EnOcean STM 300
  • Replies 12 replies
  • Subscribers 7 subscribers
  • Views 4726 views
  • enocean
robertheinze
robertheinze over 11 years ago
Hello!
I am planning to use a motion detector based on EnOcean technology. The available solar powered OEM products using the STM 300 are rather expensive (70€ and more), so I was wondering whether anyone has experience in building your own motion detector Based on STM 300 or if anyone has found a cheaper version of the product.
The idea is have it communicating with a EnOcean Pi modul on a RPi.
Thanks for help.
Regards
Robert
  • robertheinze
    robertheinze over 11 years ago in reply to ravi_butani +1
    HI Ravi, unfortunately I am not enough experienced in hardware design. I want to setup a PIR solar powered (no batty changing action because of maintenance!) sending a signal on movement detection in a…
  • ravi_butani
    ravi_butani over 11 years ago
    Hii robertheinze ....
    You can refer my post Fireman Minion: STM330 Temp-Sensor with custom Analog and Digital Input (Part1) regarding STM300 also you will find compile codes to interface external analog and digital sensor with STM300...
    All the best....
  • robertheinze
    Perfect! Thanks for your quick answer. I will have a look into it ....
    All the best
    Robert
  • ravi_butani
    ravi_butani over 11 years ago in reply to robertheinze
    I have all the setup ready at my place... Let me know if you want some extra functonality... I will send you .hex file to upload directly to STM300/STM330
  • robertheinze
    HI Ravi,
    unfortunately I am not enough experienced in hardware design. I want to setup a PIR solar powered (no batty changing action because of maintenance!) sending a signal on movement detection in a room to the EnOcean Pi. I am using a STM320 for a door coontact, which works exactly the way I need it. Unfortunately there is nothing comparable to get around the STM300.
    maybe you can give me a hint.
    sorry for my asking being a dummy image
    thanks
    robert
    dougw over 11 years ago
    You could use a PIR sensor powered by a small solar cell to drive a FET that connects across the reed switch of an STM 320.
    Here is an example of a PIR sensor:
    IRA-E700ST0 MURATA PIR Motion Sensors | 97K1948 | Newark element14 Canada
  • robertheinze
    robertheinze over 11 years ago in reply to dougw
    Thanks Douglas!
    directly instead of the reed contact?
    I am afraid, that the solar of the STM320 does not give enough output power. So it would suck out the backup battery soon. What do you think?
    dougw over 11 years ago in reply to robertheinze
    Yes the FET could directly replace the reed switch.
    You are probably correct - the PIR sensor would likely need its own solar cell to ensure the STM320 always has enough power.
  • kee
    kee over 9 years ago in reply to ravi_butani
    HI Ravi,a
    Are you still in? unfortunately,i have some issues about programming of STM300,need some  circuit diagrams of this programming. in my project,it always failes in "PrgArea falied",and I don't know what it means.
    thanks
    Lemon
  • ravi_butani
    ravi_butani over 9 years ago in reply to kee
    Forget_me_not : My Smart Home Post#9 Week-8 (Part1) Sensors@enocean and Accuator@arduino+RFtransceiver
    Try code attached in above blog with keil... Keil c51 licensed version required for creating hex file... 8kb code size limited demo version of keil c51 will not work...
    If you still get error than let me know...
    Ravi
  • kee
    hello,this is my problem.
    The EOP-350 UPB always cann't communicate  with the TCM320U,and programming the module won’t be possible.It is received the error message below
    Init device 'EOZ5VUQ5A'........................................OK
    Programmer firmware version ' DA'..............................OK
    Connected to 'EO3000I' BootLoader 'v2.3.0.0'...................OK
    Read CfgArea to buffer.........................................OK
    ERROR: FracN RX/TX values missing, radio is not available!
    Please restore your config area:
    Use DolphinStudio -> Utilities -> Restore config area from backup
    Aborting programming!
    Reset chip.....................................................OK
    Disconnect.....................................................OK
    I tried to restore EO3000I configuration area from backup and using the Programmer section of DolphinStudio to update the TCM300 and received the error message below.
    EOP-EnOcean Programmer v2.3.4.0 (c) Copyright 2009 EnOcean GmbH
    Read chip information..........................................OK
    Backup for ChipID: 0x19AB92D already exists....................OK
    Check ChipID...................................................OK
    Write PrgArea..............................................FAILED
    I really do not know what the problem is!
    thanks
    Lemon KEY
