Forum Controling the TCM320C via EnOcean Pi
  • Subscribers 3 subscribers
  • Views 1691 views
  • forget_me_not
  • iot_scho
bose
bose over 12 years ago
I have used the LRN feature to train the TCM320C with one of the switches.
I wish to know if there is a technique to send out a radio telegram to switch On and Off the Channel 0 of the TCM320C module.
Kindly help me out with this.
Warm Regards,
Abhijit
  • bose
    0 bose over 12 years ago
    I found that there is some possibility of fetching a data dump from the TCM 320 C using the EOM 305 and Dolphin studio.
    However I am not sure how to transmit the radio telegram to be able to talk to the TCM 320 C other than the switch rocker PTM200C modules.
    0 e14 Contributor over 12 years ago in reply to bose
    Hi Bose,
    You can control EnOcean atuators (e.g. TCM 320C) via a self-powered switch (e.g. PTM 200C) or via a gateway/smart home server
    (TCM 310, USB 300, EnOcean Pi).
    - USB 300: Download DolphinView, activate learn mode on your actuator and send PTM telegram via DolphinView Telegram send tab.
                     For details see EDK 350 or USB 300 user manual
    - EnOcean PI: Use FHEM or openHAB SW to get smart home server functionality. Activate learn mode on your actuator and
                          send PTM telegram for teach in. For details see FHEM or openHAB.
  • bose
    0 bose over 12 years ago in reply to e14 Contributor
    This clarifies a lot of things.
    I have the FHEM running and I am able to see the actuator events.
    However I am not sure how to generate messages from the FHEM, I am looking out for that.
    If you have any hints on how to send out the messages from FHEM, please share.
    Thanking you,
    Warm Regards,
    Abhijit
