Forum EOP 350 - How to use as Gateway?
  • Replies 17 replies
  • Subscribers 7 subscribers
  • Views 3703 views
  • forget_me_not
  • enocean
  • iot_home_intelligent
  • enocean_eop_350
  • forget-me-not-challenge-2014
vish
vish over 12 years ago
Hello All,
I'm trying to use EOP350 as a gateway to my PC. i changed the jumper setting to 'GATEWAY' and now I want to see the serial dump from EOP350 in PC. When I connect EOP350 to PC( running linux ), it shows two USB ports -- ttyUSB0 and ttyUSB1. In this USB0 is not at all responding. USB1 is responding, but i think I'm not sure about what is the correct baudrate to set. I tried everything from 9600, 19200 to 115200, but the response I'm getting is not the one I used to get with my EnOcean Pi( ESP protocol ). While setting to 57600bauds, i'm getting continuous streams of 0x00 with 0xE0 here and there. image I'm testing the response by pressing the rocker switch. I'm supposed to receive 21Bytes + 21Bytes( Press and Release ), but what I'm receiving is different
@9600 buads : 14Bytes + 14Bytes
@19200 buads : 24Bytes + 22Bytes
@57600 buads : 31Bytes + 30Bytes
I'm using 8N1 configuration for serial monitor( It worked perfectly with EnOcean Pi at 57600bauds ).
Can anybody please tell me what is the correct baud rate to set?
Thanks ahead,
vish
  • vish
    vish over 12 years ago in reply to mcb1 +1
    Good point!! It's in moments like this I wish I really had an oscilloscope But I'm connecting it to my USB. Does the polarity will affect USB communication?
  • ravi_butani
    0 ravi_butani over 12 years ago
    Nice .... So u HV received your eop350 programmer.... I am still waiting......
  • vish
    0 vish over 12 years ago in reply to ravi_butani
    Yup....received it 3 days ago.
  • verrverr
    0 verrverr over 12 years ago
    I do not know if it can help but in my video i show how to use EOP 350 for sniff sensor packet.Pas Home / EOP 350 Basic use
  • vish
    0 vish over 12 years ago in reply to verrverr
    Yes I saw that, but that doesn't give any clue about the baudrate.
    0 mcb1 over 12 years ago in reply to vish
    Not sure if it helps, but the Gateway they talk about in the manual is for the Transceivers, rather than a comm port to your PC.
    I had a look and it certainly didn't to how the programmer talks to the software.
  • vish
    0 vish over 12 years ago in reply to mcb1
    But if I switch my jumpers to gateway, I'm able to get some hex dump in serial monitor while pressing rocker switch. So I guess it can act as gateway. Only thing I have to find is the baudrate.
    You might also want to look and see that the data coming out is the correct polarity. (it may require inverting)
    It made some comment about it in the manual. (sorry don't have it avaliable at the moment)
  • vish
    Good point!! It's in moments like this I wish I really had an oscilloscope image
  • ravi_butani
    0 ravi_butani over 12 years ago in reply to vish
    Nop... polarity dont cause any damage to your setup ... but You will get junk data...
  • vish
    No..no...I'm not talking about damaging the setup.
    Even if the TCMxxx module speaks a different polarity, I'm using EOP connected via USB in my PC. And I assume in USB communication, EOP will take care of this.
    May be I'm wrong, but can't figure out why I'm wrong image
