Forum Need Help regarding HSM100 Schematic
  • Replies 13 replies
  • Answers 2 answers
  • Subscribers 6 subscribers
  • Views 3473 views
  • forget_me_not
  • element14
  • enocean
  • iot_homeauto
ravi_butani
ravi_butani over 12 years ago
Do any one have HSM100 humidity sensor schematic...? I need it for understand how my other analog sensor will talk with STM330 temperature sensor. I have tried to find it on enocean website but no luck... I have tried to get rough idea about hsm100 schematic using pics...but all pics available on internet is with bottom side..but no image from top..
Note: I do not require HSM100 for my project but I just need Schematic of HSM100 to build my custom analog sensor...
What I know from STM330 user manual is..
SWPWR is VCC and only available when module not in deep sleep
GND is ground for HSM100
ADIO3 is Analog input from HSM100
Other pins ---I have no idea
may bebryan.edelman@enocean.com can you please help me in this matter...?
  • hlipka
    0 hlipka over 12 years ago in reply to ravi_butani
    Did you look at the sensor output with a scope? Or how do you know? PWM output could mean that its using a SHT21 variant (SHT21P: http://www.sensirion.com/fileadmin/user_upload/customers/sensirion/Dokumente/Humidity/Sensirion_Humidity_SHT21P_Datashee… )
    Interestingly, there is an AppNote from Sensirion describing how to interface a SHT21 with I2C interface to the STM300: http://www.sensirion.com/fileadmin/user_upload/customers/sensirion/Dokumente/Humidity/Sensirion_Humidity_SHT21_Interfaci…
    0 mcb1 over 12 years ago in reply to ravi_butani
    If you want a HSM100 sensor, then talk to Christian.
    If you want to connect another analogue input, there is information in the User manuals for "occupancy sensor and setpoint" which shows a potentiometer.
    Presumably as a temperature setting for HVAC.
    I have also seen some other circuits as well. (sorry can't remember which module)
  • ravi_butani
    0 ravi_butani over 12 years ago in reply to hlipka
    in STM330 source code Help http://www.enocean.com/en/download/STM33x_Sources_2_4_0_2.zip/
    part of measure.c
    // DIGITAL
      140   // ********** Occupancy Measurement **********
      141   if(bgOccupancy)
      142  {
      143  io_getPort(GPIO2, &u8gGPIO2);  // Read GPIO2, to check WAKE0 pin state
      144  }
      145
      146   //startH-DONTREMOVE
      147   // ********** Humidity Sensor Measurement ********* // the selected EEP includes the measurement of the set-point analogue input?
      148   if(bgHumidity)
      149  {
      150   SCO_ON;  // switch on external sensor HW signal
      151
      152   // Get the time measurement of the periods delivered by the humidity sensor signal.
      153   if(MeasureHumiditySensPeriods() == FALSE)  // Measurement now loaded in u16gTimer0Diff
      154  {
      155  u16gTimer0Diff = NO_SENS_HUM_SIGNAL_16;  // This value indicates tha the humidity sensor was not attached
      156  }
      157  }
      158
    means HSM100 interface is not analog its PWM based...
