Forum How to send out RPS telegram to control TCM320C module from OpenHAB
  • Subscribers 5 subscribers
  • Views 1705 views
  • forget_me_not
  • iot_scho
bose
bose over 12 years ago
I am trying to send out RPS telegram from the OpenHAB rules when the Rocker on the GUI is switched - either On or Off.
In the current setup when the Rocker switch of the PTM200C module is pressed the Rocker on the GUI gets updated.
However when the Rocker on the GUI is clicked it does not send out the RPS telegram.
Kindly help me out with this.
Warm Regards,
Abhijit
  • fvan
    0 fvan over 12 years ago
    do you already have a rule set up ? If yes, can you post it here ? image
    Frederick
  • bose
    0 bose over 12 years ago in reply to fvan
    Actually that's whats the problem.
    I am not sure which EnOcean binding event would be trigged the rocker movement on the UI.
    Presently I am trying to download and setup the OpenHAB designer to get that.
    I will post if I am successful in checking reproducing the event.
    One more problem is that we don't know the base ID of the TCM310 on the EnOcean Pi.
    Do you know a technique to fetch this ?
    If so please post.
    I will try to send the Radio telegram from the TCM320 configured as a Sniffer. Once this is successful then I can control the actuator at least.
    So this will help to generate one RPS telegram to switch off all the actuators.
  • hlipka
    0 hlipka over 12 years ago in reply to bose
    I think when you enable the debug log for the enocean binding in OpenHAB, the ID will be written there (the server receives the message and writes everything it knows about it into the log).
    You can get the BASE ID or the CHIP ID via ESP3 CO commands. See the ESP3 documentation.
    -Bryan
  • bose
    0 bose over 12 years ago in reply to hlipka
    Thanks I will try out the debug mode.
  • bose
    0 bose over 12 years ago in reply to e14 Contributor
    I am still working on completing the circuit for TCM320, so once I have the Learning buttons and others I will try to send the ESP3 commands from the sniffer.
