Forum Cat 6 network Cables max Amp?
  • Subscribers 2 subscribers
  • Views 1665 views
  • forget_me_not
  • pas_home
verrverr
verrverr over 12 years ago
Hi i buy my stepper motor for my project and i will try to put the cable in the wall but i'm not sur if a Cat 5-6 network cable with 8 wire inside can handle the load. This is the link to the stepper motor https://www.adafruit.com/products/324
and Link to the cable http://ca.startech.com/Cables/Network/Cat-6/#N6PATCH100BL
I will run with 12v and they take 350mA i found on the net the network cable with 24avg can handle 30v up to 3.5A and some place 350mA
What you think? Cat6 network cable do the job?
  • turfgnome
    0 turfgnome over 12 years ago
    you are pretty much at the max that the cable will handle.  It should be fine but I suggest doubling up if you can on the cat5 wires using 2 wires per wire on the motor.  This will make the motor and wires run cooler and make it last a lot longer.
