Get Closer Wearables Design Challenge
  • Get Closer Wearables Design Challenge
Blog FLORA Color Sensor TCS34725 issue
  • Author Author: chris.carter
  • Date Created: 29 Aug 2013 3:46 PM Date Created
  • Views 1129 views
  • get_closer_challenge
  • adafruit
  • get_closer
chris.carter
chris.carter
29 Aug 2013
For our furry cosumes, I want the orange leds in one costume to trigger red neopixels in another costume to light up.  However, whenever I shine the light of the orange led strip on the FLORA color sensor the color sensor shuts down after about three readings and the serial monitor stops printing readings.  Then I have to reload the tcs34725 sketch twice before the color sensor will begin again.  This happens whether the color sensor onboard led is on or not.  I am running the led strip at a low voltage and am not overpowering the color sensor with light.  Has anyone faced this problem before?  I am using the example code below.
#include <Wire.h>
#include "Adafruit_TCS34725.h"
/* Example code for the Adafruit TCS34725 breakout library */
/* Connect SCL    to analog 5
   Connect SDA    to analog 4
   Connect VDD    to 3.3V DC
   Connect GROUND to common ground */
/* Initialise with default values (int time = 2.4ms, gain = 1x) */
// Adafruit_TCS34725 tcs = Adafruit_TCS34725();
/* Initialise with specific int time and gain values */
Adafruit_TCS34725 tcs = Adafruit_TCS34725(TCS34725_INTEGRATIONTIME_700MS, TCS34725_GAIN_1X);
void setup(void) {
  Serial.begin(9600);
  if (tcs.begin()) {
    Serial.println("Found sensor");
  } else {
    Serial.println("No TCS34725 found ... check your connections");
    while (1);
  // Now we're ready to get readings!
void loop(void) {
  uint16_t r, g, b, c, colorTemp, lux;
  tcs.setInterrupt(true);  // turn off LED
  tcs.getRawData(&r, &g, &b, &c);
  colorTemp = tcs.calculateColorTemperature(r, g, b);
  lux = tcs.calculateLux(r, g, b);
  Serial.print("Color Temp: "); Serial.print(colorTemp, DEC); Serial.print(" K - ");
  Serial.print("Lux: "); Serial.print(lux, DEC); Serial.print(" - ");
  Serial.print("R: "); Serial.print(r, DEC); Serial.print(" ");
  Serial.print("G: "); Serial.print(g, DEC); Serial.print(" ");
  Serial.print("B: "); Serial.print(b, DEC); Serial.print(" ");
  Serial.print("C: "); Serial.print(c, DEC); Serial.print(" ");
  Serial.println(" ");
  • zengirl2
    zengirl2 over 13 years ago
    Chris,  I haven't tried my color sensor yet to see if I have a similar issue.  I know working in video the colors of red and orange can be problematic.  Does the same happen with other colors or is it just on these.  I'm sure you have probably tried Adafruit's forum already -- I would definitely post your question there if you haven't already.  I know I won't be home this evening, but I will try to test my color sensor tomorrow since I will need to use it on my umbrella anyway.  I will definitely try different colors to see what happens and report back.
