Hats Off Design Challenge
  • Hats Off Design Challenge
Blog Everything electrical in the helmet
  • Author Author: malakai
  • Date Created: 31 Oct 2014 2:30 PM Date Created
  • Views 1208 views
  • iron_man
  • hats_off
  • iron_man_helmet
malakai
malakai
31 Oct 2014
Hey guys! This is the second to last post! In this video, I measure, assemble, solder, and place the wires/tech in the helmet.
Things to note:
-all the electronics work fine (even now that I'm done completely) EXCEPT for one neopixel, which is broken. I except that.
-I did hot glue all the electronics in (they work fine)
-I've never soldered before, don't expect the best of work!
Things used:
-1 Gemma
-1 Lipo battery
-1 Tactile push button switch
-8 neopixels
-lots of wire and solder!
Code used:
(copying and pasting the code took to much space)
look for it here: (just scroll down)
https://learn.adafruit.com/superhero-power-plant/build-it
Special thanks:
To tom for loaning soldering stuff.
To mom for helping me strip wire (<- this was a requested portion of thanks)
Its been a while since I took this video, and now I AM FINISHED! Just have to post the last video! I can't believe how far I've gotten, thanks to everyone who watched/read!
    DAB over 12 years ago +1
    It is clear that you are learning a lot during the challenge. Soldering skills come with practice. In tech school, we spent hours soldering connections and testing them. The SMD components make it essential…
  • malakai
    malakai over 12 years ago in reply to DAB
    Thanks! I'd like to say I learned a lot, but I'm still a beginner. It definitely has been a great experience, a hope to do something like this again.
    The SMD components make it essential that you have both a small soldering tip and a rig to keep the parts still while you apply solder and heat.
    Overall I think you did a pretty good job for your first adventure.
    I look forward to your final post and your thoughts about what you think you learned during the challenge.
