Hats Off Design Challenge
  • Hats Off Design Challenge
Blog Hats Off Fascinator 3: IDE Struggle and a Fix
  • Author Author: brenyc13
  • Date Created: 23 Aug 2014 3:06 PM Date Created
  • Views 937 views
  • ide
  • jaunty_fascinator
  • hats_off
  • adafruit
brenyc13
brenyc13
23 Aug 2014
A video in which I discuss a problematic encounter with the Arduino IDE, reconcile myself to receiving help, and learn a valuable lesson.
If you don’t want to watch my mini-maker-crisis or meet my uber-smart spouse, here’s the gist:
Dude, where’s my program?
Avrdude in the Arduino IDE was messing up, not loading the Blink program, and giving me oodles of error messages. This doesn’t seem to be a unique problem. However, the fixes that I found on my own didn’t work.
My error messages:
avrdude2: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.01s
avrdude2: Device signature = 0x1e930b
avrdude2: NOTE: FLASH memory has been specified, an erase cycle will be performed
          To disable this feature, specify the -D option.
avrdude2: erasing chip
avrdude2: error: usbtiny_receive: usb_control_msg(DeviceRequestTO): unknown error (expected 4, got -1)
avrdude2: error: usbtiny_transmit: usb_control_msg(DeviceRequestTO): no connection to an IOService
avrdude2: reading input file "/var/folders/xb/1ldh3kns121_9sxt8b_9qgpw0000gn/T/build3845907724888873706.tmp/sketch_aug17a.cpp.hex"
avrdude2: writing flash (832 bytes):
Writing |
avrdude2: error: usbtiny_send: usb_control_msg(DeviceRequestTO): no connection to an IOService (expected 64, got -6)
avrdude2: error: usbtiny_receive: usb_control_msg(DeviceRequestTO): no connection to an IOService (expected 4, got -6)
# | 100% 0.42s
avrdude2: 832 bytes of flash written
avrdude2: verifying flash memory against /var/folders/xb/1ldh3kns121_9sxt8b_9qgpw0000gn/T/build3845907724888873706.tmp/sketch_aug17a.cpp.hex:
avrdude2: load data flash data from input file /var/folders/xb/1ldh3kns121_9sxt8b_9qgpw0000gn/T/build3845907724888873706.tmp/sketch_aug17a.cpp.hex:
avrdude2: input file /var/folders/xb/1ldh3kns121_9sxt8b_9qgpw0000gn/T/build3845907724888873706.tmp/sketch_aug17a.cpp.hex contains 832 bytes
avrdude2: reading on-chip flash data:
Reading |
avrdude2: error: usbtiny_receive: usb_control_msg(DeviceRequestTO): no connection to an IOService (expected 128, got -6)
# | 100% 0.01s
avrdude2: verifying ...
avrdude2: verification error, first mismatch at byte 0x0000
          0x20 != 0x00
avrdude2: verification error; content mismatch
avrdude2: safemode: Fuses OK
avrdude2 done.  Thank you.
How did you stop crying?
I was mostly mad that I couldn't figure it out on my own. But once I worked through that utterly unreasonable expectation, it was fun to have the help of my Spouse/Hunky Assistant. He hacked-up a fix to avrdude that seems to work. And actually, watching a bunch of those Made With Code videos really helped ease my frustration. Google, I know I'm probably not your target age group, but that *** works.
So what’s the fix?
As my Hunky Assistant explains it, there seemed to be a timing issue in avrdude making it think that it failed at erasing the chip. So avrdude got confused and didn’t upload the Blink program. To fix this, Hunky Assistant made a wrapper around avrdude that first deletes the chip in a separate command, waits a few seconds, and then runs avrdude without the built-in chip-erase. We still got a ream of error messages, but the uploading worked.
And, in case you're curious, here’s Hunky Assistant’s code:
#!/bin/bash
echo "$@" >/tmp/args.txt
# Erase
"/Users/BarbaraEldredge/Desktop/Adafruit Arduino 1.0.5.app/Contents/Resources/Java/hardware/tools/avr/bin/avrdude2" "-C/Users/BarbaraEldredge/Desktop/Adafruit Arduino 1.0.5.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf" -q -q -pattiny85 -cusbtiny -e
# Wait
sleep 5
# Upload
"/Users/BarbaraEldredge/Desktop/Adafruit Arduino 1.0.5.app/Contents/Resources/Java/hardware/tools/avr/bin/avrdude2" "$@" -D
Really? That's what you're going to use?
Weeeeell... last night I downloaded the Arduino IDE onto my nicer, newer work laptop and the upload functioned perfectly on the first go without any hacky-fiddling. So the real lesson I've learned is to always use the latest, most up-to-date software in order to avoid unexpected problems. I'm planning on just using my work laptop for everything going forward.
Thanks for reading.
  • vish
    vish over 12 years ago
    Hi Barbara,
    Became a great fan of your presentation style. Surely you are making a difference in this gray toned "technical" place. Really really like that.... image
    Oh God....I wish I can also post my blogs like her.
    Congrats and best wishes image
    And one more thing -- is it this tee shirt your "assistant" wearing?
  • vish
    Hi Barbara,
  • brenyc13
    brenyc13 over 12 years ago in reply to vish
    Hi Vishnu,
    Thanks so much for your support. It feels really great to hear this kind of feedback from you. You've totally made my day.
    Also, yes, that's the shirt my spouse was wearing. I think he got it from Tektronix for entering a contest in the spring.
