In the Air Design Challenge
  • In the Air Design Challenge
Blog [Air ex Machina] #02 LaunchPad cc3200 first play
  • Author Author: nikil511
  • Date Created: 2 Nov 2014 1:37 PM Date Created
  • Views 897 views
  • internet_of_things
  • energia
  • in_the_air
  • air_ex_machina
  • texas_instruments
  • cc3200
  • launchpad
nikil511
nikil511
2 Nov 2014
I am not the “read the manual” kind of person, so I searched for energia + cc3200, found this:
http://energia.nu/pin-maps/guide_cc3200launchpad/
had a quick look at the instructions and started downloading/installing software. I’m runing windows 8.1 64bit, so I ‘ve installed drivers for FTDI via DPInst64.exe from cc3200_drivers_win
Then extracted energia-0101E0013-windows.zip and runned energia, selected correct COM, loaded blink sample, upload and….
Opening COM4
Read ACK failed
Failed to trigger bootloader
I later found this link which explains things:
http://processors.wiki.ti.com/index.php/CC32xx_Quick_Start_Guide?DCMP=cc3100cc3200&HQS=cc3200launchpadstart
CC3200 comes preloaded with a demo web server / access point. That's cool. I scanned for wifi on my Android, and simplelink, out of the box was there, working as it should…played with the demo apps, very nice way to start with these boards.
I continued with “project 0 guide” ..and realized that I had to move jumper from P58-VCC to SOP2. Tried to upload a blink sample code and..
Opening COM4
Getting storage list
Bootloader Version: 3
Silicon version ES1.32
Bootloader version is 2, 0, 3, 2
It's a CC3101 device: PG1.32
BlockSize is 4096, number of blocks is 64
erasing 1 blocks starting from  4
Switch to NWP bootloader complete
Bootloader version is 2, 0, 3, 4
BlockSize is 4096, number of blocks is 16
erasing 12 blocks starting from  0
erasing file "/sys/mcuimg.bin"
deleting file "/sys/mcuimg.bin"
erase file completed
Downloading file "/sys/mcuimg.bin" with size 4128
..Download complete
However, still no led blink.. pressed reset, nothing changes, removed SOP2, pressed reset, and yes, we have a blink! :-)
Next post: [Air ex Machina] #03 CC3200 with CCStudio
  • nikil511
    nikil511 over 11 years ago in reply to amgalbu
    yes, I kitesurf when I have time (lately less and less).
    I have not played with CCS yet, but will do so in the comming days, and will post about it. I have a felling I will prefer CCS, as it is eclipse based and I am working on eclipse for many years now on a daily basis (java developer), so I guess atleast I will be familiar with a portion of the "enviroment". I guess Energia is mainly nice due to its simplicity and makes sense when moving from Arduino, so you are not scared by the complexity of a more advanced IDE. However once you become familiar with (any) advanced tool/IDE, you usually do not go back to simple ones.
  • amgalbu
    amgalbu over 11 years ago
    You think Energia is a good IDE? Still trying to choose between CCS and Energia...
    OT... are you a kitesurfer?
    DAB over 11 years ago
    Well written.
    I will have to give this a try.
