In the Air Design Challenge
  • In the Air Design Challenge
Blog Pollution Effect Minimiser (Post 6)
  • Date Created: 22 Dec 2014 9:01 PM Date Created
  • Views 629 views
  • iot_pollution_effect
  • in_the_air
e14 Contributor
e14 Contributor
22 Dec 2014
Sending sensor readings to airvantage :
For this i connected airvantage to the beaglebone black and after its connected go to  http://192.168.7.2:3000/
This is the cloud9 workspace.
Now in the cloud9 workspace go to terminal and in the default cloud9 location run the following :
npm install mqtt
This installs the necessary mqtt module for nodejs in cloud9 directory.
Next I created a sample file using the following code to send data to airvantage :
var mqtt = require('mqtt');
var port = 1883;
var server = "na.airvantage.net";
var serialnumber = "3713BBBK7777";                   //serialnumber of your beaglebone
var password = "1234"; //password used in credentials
var mqtt_options = {username: serialnumber, password: password};
var client = mqtt.createClient(port, server, mqtt_options);
console.log("Client started");
//Send values
console.log("Sending value");
//Publish a message on the right topic
var room_1= {};
var timestamp = new Date().getTime();
room_1[timestamp] = { "room1.temperature": 42.2, "room1.threshold": 30, "room1.humidity": 42.2, "room1.dust": 42.2, "room1.co": 42.2, "room1.co2": 42.2,};
client.publish(serialnumber + '/messages/json', JSON.stringify(room_1));
console.log(room_1);
Save this file and run the file in cloud9 workspace.
Thats it . Next go to your airvantage account and go inventory >  systems > your device > timeline tosee if the readings are being uploaded. On the timeline you can see all the readings that are uploaded.
