Internet of the Backyard
  • Internet of the Backyard
Blog Connect the CC3200 to the Internet of Things with MQTT and Paho embedded C client - Part 1
  • Author Author: kartben
  • Date Created: 25 Aug 2014 5:11 PM Date Created
  • Views 1659 views
  • mqtt
  • iot_backyard
  • eclipse
  • internet_of_things
  • cc3200_launchpad
  • paho
  • iot
kartben
kartben
25 Aug 2014
In this 20-min video you will learn how to connect your TI CC3200 LaunchPad to the Internet of Things using MQTT.
Once your board is pushing data using MQTT, not only can you test that everything is properly working by using the MQTTLens Chrome app mentioned in the video, but you can use virtually any MQTT client to consume the data and display it on a chart, store it in a database, etc.
The MQTTTask code is as follows, in case you'd like to copy-paste it image
static void MQTTTask(void *pvParameters) {
  while(g_iInternetAccess != 0) {
  osi_Sleep(200);
  while(1) {
  // publish temperature using MQTT
  MQTTPacket_connectData data = MQTTPacket_connectData_initializer;
  int rc = 0;
  char buf[200];
  MQTTString topicString = MQTTString_initializer;
  float fCurrentTemp;
  TMP006DrvGetTemp(&fCurrentTemp);
  char cTemp = (char)fCurrentTemp;
  char payload[20];
  memset(payload, '\0', sizeof(payload));
  short sTempLen = itoa(cTemp,payload);
  payload[sTempLen++] = ' ';
  payload[sTempLen++] = 'F';
  payload[sTempLen] = '\0';
  int payloadlen = strlen(payload);
  int buflen = sizeof(buf);
  data.clientID.cstring = "me";
  data.keepAliveInterval = 20;
  data.cleansession = 1;
  int len = MQTTSerialize_connect(buf, buflen, &data); /* 1 */
  topicString.cstring = "cc3200-ben";
  len += MQTTSerialize_publish(buf + len, buflen - len, 0, 0, 0, 0, topicString, payload, payloadlen); /* 2 */
  len += MQTTSerialize_disconnect(buf + len, buflen - len); /* 3 */
  int mysock = sl_Socket(SL_AF_INET, SL_SOCK_STREAM, 0);
  SlSockAddrIn_t addr;
  addr.sin_family = SL_AF_INET;
  addr.sin_port = sl_Htons(1883);
  addr.sin_addr.s_addr = sl_Htonl(0xC6291EF1);
  sl_Connect(mysock, (SlSockAddr_t *) &addr, sizeof(addr));
  sl_Send(mysock, buf, len, NULL);
  sl_Close(mysock);
  osi_Sleep(1000);
  • ipv1
    ipv1 over 12 years ago
    Full rocking.
  • ipv1
    Full rocking.
