Just Encase
  • Just Encase
Just Encase
Blog Addendum_BLOG_B_References_BLOG3
  • Author Author: skruglewicz
  • Date Created: 19 Feb 2022 9:06 PM Date Created
  • Views 1009 views
skruglewicz
skruglewicz
19 Feb 2022
imageAddendum Blog B REFERENCES (Case Enclosure Reliability Monitor)
This blog is an Addendum for the link references in BLOG#3 - Implementation.
Connect to Arduino Cloud from far away with LoRaWAN and The Things Stack
The Things Stack (TTS) and Arduino Cloud are now fully interfaced and open up a world of connected opportunities. When you configure a LoRaWAN device now, it’ll automatically be registered on The Things Stack platform, too.
LoRa made easy: Connect your devices to the Arduino IoT Cloud
An important new feature is now available in the Arduino IoT Cloud, full support for LoRa® devices!
Configuring LoRaWAN® devices in the Arduino Cloud
Connect your LoRaWAN® devices to the Arduino Cloud platform via The Things Network.
Send Data Using LoRa® with MKR WAN 1300
This Tutorial was used to implement the LoRa Sender and receiver scripts on the MKR1 and the MKR 2
    Jan Cumps over 4 years ago +1
    I used the same LoRaWan tutorial as you. All setup on the Arduino Cloud and TTN , and loading my little sketch to the MKR WAN 1310 worked. I haven't been successful getting data out though. Probably…
  • skruglewicz
    skruglewicz over 4 years ago
    I've finished this design challenge
    I hope everyone had as much fun as I did.
    CHECK the other blogs in this series with this search.
    • ALL THE BLOGS IN THE Just Encase Series
    Steve K  (skruglewicz)
  • skruglewicz
    skruglewicz over 4 years ago in reply to Jan Cumps
    Thanks Jan Cumps
    I did see your detailed comment in my blog.
    I had to break out the links to a separate blog, due to link retractions on the new site CMS.
    I was getting sick of being thrown into page moderation every time I update my post!Nerd
    Steve K
    All setup on the Arduino Cloud and TTN , and loading my little sketch to the MKR WAN 1310 worked. I haven't been successful getting data out though. Probably due to lack  coverage.
    The error I get is "move closer to the window". Which I did, including moving it outside. And the Arduino is fitted with a proper antenna for the range.
