Just Encase
  • Just Encase
Just Encase
Blog Blog 4 - Arrivals, Github and requirements
  • Author Author: christophesky
  • Date Created: 16 Dec 2021 11:47 AM Date Created
  • Views 1969 views
  • Likes 11 likes
  • Hammond Manufacturing Enclosures
  • Arduino MKR 1300 Lora
  • remote monitoring
  • grove
  • just_encase
christophesky
christophesky
16 Dec 2021
Unboxing
I cannot say I ever expected to make an unboxing video :D but its like Christmas, but for makers so why the heck not. Its arrived. Lets look inside.
Github
I have now created a github repo for code and hardware, this will be updated as I go along Slight smile you can find it here:
https://github.com/christopherusky/just_encase_challenge/blob/main/README.md
Requirements
Requirements - Remote environmental monitoring solution.
Challengers must build projects for a hazardous environment, such as extreme cold and heat or exposure to water and humidity. Your project could be designed for the industrial environment, outdoor monitoring, food production areas, and more.
High Level Requirements
  • Ascertain if any nearby The Things Network gateways (if so, consider vs. at home solution)
  • Must provide a remote environmental monitoring solution
  • Must explain / provide rationale for each sensed data point and the hardware selection
  • Must be weather proof and make use of a Hammond Manufacturing Enclosure
  • Must demonstrate the weatherproofness of the enclosure
    • Potential submergence testing prior to deployment
    • Without cable glands, 100% sealed test
    • With cable glands and sealed stubs, for sealed test
  • Must be capable of being battery or mains powered
  • Must provide the defined monitoring parameters - for water and environment
  • Must use Lora connectivity, no gateway but point to point.
  • Must be built around the Arduino MKR 1300 (see above requirement)
  • Needs to use a 3.3v input for the Arduino
  • Must be in place for sufficent time to record data
  • Must demonstrate solution
  • Must provide data connectivity to store recorded values
  • Must provide sample data every n-minutes - provide rationale on sample period selection, also work through storage reqs
  • Must provide data visualisation of parameters recorded
  • Must provide code for final solution
  • Must provide build instructions
  • IF home solution, must provide detailed design and deployment information (to be repeatable)
Solution specification
Monitoring parameters
Must be capable of monitoring and providing absolute values for:
  • Air temperature
  • Humidity
  • Air pressure
  • Water pH
  • Water turbidity
  • Total Disolved Solids (TDS)
  • Water temperature (potentially at surface and at depth)
Potential Solution specification additions
  • Ambient light level measurement, LUX
  • Oxidisation Reduction Potential (ORP) if i can find a vendor with any stock that isnt £140
  • Air temperature
  • Humidity
  • or  / Air temperature + Humidity in a single package,
  • Air pressure
  • Water pH
  • Water turbidity - Gravity: Analog Turbidity Sensor
  • Total Disolved Solids (TDS) - Gravity: Analog TDS Sensor
  • Ambient light level measurement, LUX - Adafruit VEML7700 Lux Sensor
  • View
  • Hide
  • robogary
    robogary over 4 years ago in reply to christophesky +2
    video played OK. It always exciting to scalpel open a Newark shipment :-)
  • javagoza
    javagoza over 4 years ago +1
    I love that kit, you are going to have a lot of fun.
  • scottiebabe
    scottiebabe over 4 years ago +1
    What a kit! The only thing missing is some batteries. Nice to see Made In Canada on something for once. Well done Hammond.
  • christophesky
    christophesky over 4 years ago
    If the video does not work as it has been "Video is being processed, It will be available here soon" for a little while, I will add a seperate link :)
  • robogary
  • robogary
