Just Encase
  • Just Encase
Just Encase
Blog Blog 4: Landslide monitoring for the Himalayan region- Putting it all together and testing
  • Author Author: rsjawale24
  • Date Created: 27 Feb 2022 6:38 PM Date Created
  • Views 999 views
  • Arduino MKR WAN 1300
  • just encase design challenge
  • vibration sensor
  • landslide_monitoring
  • just_encase
  • just encase
rsjawale24
rsjawale24
27 Feb 2022
Assembling all the parts together
In this blog, I will put together all the components of the landslide monitoring system - The vibration sensor, the buzzer and the Arduino inside the enclosure box. I chose the non-transparent 1554UGY water-tight enclosure box to prevent the electronics from any rainwater or any possible collapse of the box into a nearby river or valley due to a landslide.
The complete system looks like this  -
Here's the code for triggering the alarm and reading the signal from the vibration sensor.
int a;    //variable to store the vibration sensor signal
void setup() {
  // put your setup code here, to run once:
pinMode(5,INPUT); //pin for vibration sensor
pinMode(6,OUTPUT); // pin for buzzer
digitalWrite(6,LOW); //initialise buzzer to off state
void loop() {
  // put your main code here, to run repeatedly:
  a = digitalRead(5);
  if(a==0)
    a = 0;  //latch the state of the vibration sensor
    while(1){   //keep the buzzer on infinitely
     digitalWrite(6,HIGH);   //sound the buzzer
The Arduino continuously monitors the status of the vibration sensor and as soon as the sensor is triggered, the arduino sounds the buzzer alarm and the LEDs to indicate a landslide. If the audio alarm is loud enough, this can be heard at a long distance and hence accidents can be prevented. The entire electronics is powered using a power bank. In the future, I plan to make a solar version of this so that the power bank can be charged from the solar panel and it won't require an external power source.
In the next blog, I will test the system in the field.
