Just Encase
  • Just Encase
Just Encase
Blog Blog 5: Landslide monitoring for the Himalayan region- Testing the enclosure in the field
  • Author Author: rsjawale24
  • Date Created: 28 Feb 2022 7:58 AM Date Created
  • Views 1509 views
  • Arduino MKR WAN 1300
  • just encase design challenge
  • landslide_monitoring
  • just_encase
  • just encase
rsjawale24
rsjawale24
28 Feb 2022
In the last blog for the Just Encase Design Challenge, I'm publishing the results and the videos of the landslide monitoring system. The enclosure box contains the electronics that detects the vibrations triggered due to the landslide and sounds an alarm. Various locations were chosen of different altitudes and the enclosure box was put to test by dropping it from the mountains in harsh terrain with stones and mud.
Here are the videos of the tests and some photos of the enclosure box after all the tests.
I did many tests with the enclosure and surprisingly it did not break. From the video, it can be seen that the box is hitting various terrains, from plants to rocks and it did not break at all. It got only a few scratches.
This concludes the testing of the enclosure. The enclosures are really tough and durable and can withstand rough terrains. The only problem I face was mounting the electronics inside the enclosure as the electronic parts were smaller in size as compared to the enclosure.
    DAB over 4 years ago +1
    Did you try a test where you buried the box with falling rocks and gravel?
  • dansmith57
    dansmith57 over 4 years ago
    Those boxes are ABS no?
