Just Encase
  • Just Encase
Just Encase
Blog Blog 6 - The Soak Test UPDATE 4 (Test 4 - pass but user failed)
  • Author Author: christophesky
  • Date Created: 1 Jan 2022 10:00 AM Date Created
  • Views 3163 views
  • Likes 12 likes
  • Comments 8 comments
  • Enclosure Case 1554UGY
  • Water Tight ABS 200x120x90 Enclosure
  • garden pond monitor
  • waterproof or not
  • soak test
  • just encase
christophesky
christophesky
1 Jan 2022
In one corner we have the Enclosure Case 1554UGY (Water Tight ABS 200x120x90 Enclosure) and in the challenger corner we have a washing up bowl (well my Greenhouse potting tub) and plenty of cold water.
Test Parameters:
  • 24 hour test duration.
  • Fully submerged
  • Left outside for the duration
Hypothesis: The enclosure shall indeed be proven to be water tight as advertised.
I will edit and update this post as experiments continue (its only messing about if you dont write it down!)
I give you, the Soak Test #1
Subsequent tests (before and then resuming after Christmas)
  • Test 2# deeper submergence, more pressure on the gasket seal, same 24 hour duration, same outside.
  • Test 3# hose or power washer exposure
  • Test 4# a selected combination of 1,2,3 with cable glands fitted, with stub cables.
Also, for the 1554H2GYCL IP68 60x119x180 PolyCarbonate Enclosure, whilst with the gasketed lid with two piece “tongue & groove” construction provides protection against access of oil, dust and water, it is rated up to IP68, lets find out.
Note to self, find the proper test methodology for IP / nema ratings and replicate, if not impossible to do so Slight smile
Test 1 Results - PASS
Test 2
Test 2 Results - PASS
A full 24 hours later and Test 2# deeper submergence, more pressure on the gasket seal, same 24 hour duration, same outside, all passed. Dry as a bone inside.
As a continuation of this as I am not yet ready or at a point of fitting hardware and cable glands I am going to continue with the soak test 2. No video this time I am afraid, heavy rain at the moment and I needed the hand for the umbrella! Slight smile
Extended Test 2 Results - PASS, PASS, PASS
Test results 2 in, pass.
  • Test 2 repated with and extended test duration.
  • Quick check at  +24 hours (Christmas Eve) - PASS
  • Quick check at +48 hours (Christmas Day) - PASS
  • Quick check at +72 hours (Boxing Day) - PASS
  • Quick check at +96 hours (back to normal) - PASS
and a bonux +24 hours taking total soak time to 144hrs - PASS
Video for your enjoyment / amusement.
Pass being given as did water in get? Yes, fail, No, Pass.
Test 3 Results - PASS, PASS, PASS
Test results 3 in, pass.
  • Test 2 repated with ADDED PRESSURE - sump pump blasting
Test 4 Results - PASS, PASS, PASS (USER FAILED)
  • christophesky
    christophesky over 4 years ago +1
    https://www.eag.com/resources/appnotes/ingress-protection-ip-testing-ingress-of-water-and-dust/ There is now a need to rig up a protractor in combination with a 1bar pressure washer and thinking about…
  • christophesky
    Test results 1 in, pass. Test 2 underway, results in c24 hours. Blog updated
  • christophesky
    Test results 2 in, pass. Test 2 repated with and extended test duration. Quick check at +24 hours (Christmas Eve) Quick check at +48 hours (Christmas Day) Quick check at +72 hours (Boxing Day…
  • christophesky
    Blog updated
  • christophesky
    Blog updated
  • christophesky
    There is now a need to rig up a protractor in combination with a 1bar pressure washer and thinking about how to manage a oscillating spray for the test min duration of 10 minutes.
