Just Encase
  • Just Encase
Just Encase
Blog Blog 8 - Measure, send, receive, transform, store, display (updated with code)
  • Author Author: christophesky
  • Date Created: 30 Dec 2021 7:50 PM Date Created
  • Views 1375 views
  • Likes 10 likes
  • node red
  • design_challenge
  • Ubuntu
  • Hammond Manufacturing Enclosures
  • Arduino MKR WAN 13000
  • influxdb
  • just_encase
christophesky
christophesky
30 Dec 2021
Its alive.
TLDR: Sensors + Ard MKR 1300 Sender -> LoRa -> Ard MKR 1300 Reciever ->Serial to Raspberry Pi -> Node Red Flow to process -> Write to Influx DB -> Display in Grafana.
Set up as below
Node Red
I have now updated my node red flow to make use of the split and switch:
Flow in more detail:
Serial Port Node
Configures the serial port for the raspberry pi <--> Arduino connected over USB.
CSV Node
My LoRA message payload is a comma seperated string of values, if any single sensor fails to return a value, the position in the string gets 999 as a value.
Columns gives the position for each sensor value coming over in the LoRa payload.
Split Node
The split node is told that hey, I am splitting my string using ... whatever character you chose, or as an array, or handle is as an object
Switch Node
This lovely node is the most useful, so you can take one payload message which contains multiple sensor readings and then create n outputs to write to Influx
Influx Node
Each switch node output has a matching InfluxDB node, in this case the measurement is temp to be written to Influx
* I am still figuring out node red and the useful, and dont do thats. So will update as I go. (or please do not take my example as a good example of how to do it, or at least not quite yet anyway).
Dashboard
And a quick dashboard view using Grafana, RSSI, Pressure, Temp, Humidity at the moment.
  • christophesky
    christophesky over 4 years ago +1
    Next, finish sensor calibrations (TDS, pH, Turbidity). Add water temp probe. Finish code refactoring. Get it all seated in the enclosure and outside in the pond. Measure measure measure. :)
  • christophesky
    My sketch file (ino) for sensors in a working state can be found here: https://github.com/christopherusky/just_encase_challenge/blob/main/software/arduino/sensorsender.ino
    I am refactoring at the moment to make it a little cleaner and adding in mark up on what each piece does.
    I have temporarily removed the TDS function as this is not behaving as expected and I am unsure if my code OR hardware, or a possibly a mix of both (or it might justy be the price of onions today?)
  • christophesky
    I have now included the flow file here: https://github.com/christopherusky/just_encase_challenge/blob/main/software/raspberrypi/node-red-flow.txt
  • christophesky
