Make Life Accessible
  • Make Life Accessible
Blog EyeLiner - Post 4 - Installing Pygaze
  • Author Author: amgalbu
  • Date Created: 5 May 2016 8:43 AM Date Created
  • Views 577 views
  • makelifeaccessible
  • python
  • eyeliner
  • opencv
  • make_life_accessible
  • pygaze
amgalbu
amgalbu
5 May 2016
After installing OpenCV, we are now ready to install PyGaze.
First of all, let's install all dependencies (some depencies may have been already installed, but let's stay on the safe side)
In a terminal window , type
sudo apt-get install python-numpy python-scipy python-matplotlib python-imaging python-pygame psychopy python-pyglet
This will install (in order): NumPy, SciPy, Matplotlib, PIL, PyGame, PsychoPy, and pyglet:
Installing PyGaze requires copying the PyGaze directory into Python’s site-packages directory. First check where this directory is located. One way to do this is with Python. To check which is the site-packages directory, type
python
>>> import site; site.getsitepackages()
/usr/local/lib/python2.7/dist-packages/
>>> quit()
In order to install PyGaze, download the latest version of pygaze from github
$ wget https://github.com/esdalmaijer/PyGaze/archive/master.zip
Go to the directory where the download was saved (for me, cd ~). To unzip PyGaze, in the terminal type:
unzip pygaze.zip
To copy the unzipped PyGaze directory into the site-packages directory, type the following in your terminal (of course, you should use the site-packages directory you got from above):
sudo cp -r pygaze /usr/local/lib/python2.7/dist-packages/
Set the permissions to drwxr-sr-x:
sudo chmod 2755 -R /usr/local/lib/python2.7/dist-packages/pygaze/
To test if everything was right, I tried to import the pygaze package from a Python console
python
>>> import pygaze
As no errors were shown, everything worked perfectly
There are several example experiments located by default in the directory pygaze/examples/. The PyGaze developers also provide many examples on their website. One that they recommend to start with is the “Simple Tracker Experiment”, which can be downloaded here:http://www.pygaze.org/resources/examples/simple_tracker_experiment.zip.
Unzip, enter the unzipped directory, and let the fun begin by typingpython simple_tracker_experiment.pyin the terminal.
    DAB over 10 years ago
    Nice post,
    Are you going to provide some pictures or video collected using the pygaze?
  • amgalbu
    amgalbu over 10 years ago in reply to DAB
    Hi DAB
    Well currently the eyetracker is non integrated in PyGaze, I am currently working to create a class that wraps the webcam eye tracker and implements the methods of the BaseEyeTracker class. After that, I will for sure publish the results of the analysis
    cheers
    Ambrogio
  • amgalbu
    Hi DAB
    cheers
    Ambrogio
