Make Life Accessible
  • Make Life Accessible
Blog Make Life Accessible - Motor Suite Test - blog 8
  • Author Author: dougw
  • Date Created: 29 May 2016 9:24 PM Date Created
  • Views 2496 views
  • Comments 19 comments
  • make life accessible
  • pmsm_motor_control
  • accessibility_projects
  • kinetis_motor_suite
  • mla
  • clear_walk
dougw
dougw
29 May 2016
This entry is a first exploration of the Kinetis Motor Suite capabilities, demonstrating motor reversing and sequencing through several states.
Next time I will try to hook up the Hall effect sensors to see if I can work at lower speeds.
Relevant Links
MLA Design Challenge
The full set of Clear Walk project blogs can be found here:
  • kulky64
    kulky64 over 10 years ago +2
    How do you think will Hall effect sensors help you at lower speeds? The state of the Hall effect sensors changes every 60 degrees of electrical revolution. This is of little help to FOC algorithm. They…
    shabaz over 10 years ago in reply to dougw +2
    Hi Doug, The hall sensors should always allow you to know which phase in the commutation cycle you're at (i.e. even with a stall), whereas with the sensorless method you won't know at very slow speeds…
  • kulky64
    kulky64 over 10 years ago in reply to dougw +2
    All true, but applies to BLDC motor with six-step commutation (sometimes called block commutation). But you are dealing with PMSM motor and Field Oriented Control (FOC) with all three phases driven at…
    DAB over 10 years ago
    Nice update Douglas.
    I am curious about your low speed issues.  Is it a case of needing the right sequence and is that an issue for how you can load the motor?
    Have you looked at the similarities with the TI Instaspin approach?
    Thanks
    dougw over 10 years ago in reply to DAB
    Hi DAB.
    I have not looked at the TI approach.
    I noticed when setting a low speed demand that the system would eventually lose its correct commutation timing, especially under load, and just vibrate back and forth. It still seems to have enough torque to rotate, (after all, I am running with no load) - it just seems the commutation timing is no longer correct. I guess if it is not spinning, there is no back-emf to sense commutation position.
    Doug
    Hi DAB.
    Doug
