My Project Is Trash
  • My Project Is Trash
My Project Is Trash
Forum EcoMate #1: From abstract to plan – how EcoMate will work
  • News
  • Projects
  • Enroll
Join My Project Is Trash to participate - click to join for free!
  • Subscribers 1 subscriber
  • Views 9 views
  • ecomate
  • cn0569
  • camdenboss
  • robot
  • electromagnet
  • my project is trash
  • adxl372
  • hammond
  • robotic arm
  • recycling
Humanixtech
Humanixtech 42 minutes ago
Previous post: A Special Thank You to element14 – My First International Sponsored Kit!
Hello everyone, Raju from Humanix Tech Lab again. In my application I described EcoMate in a few paragraphs. In this post I turn each promise in that abstract into a detailed engineering plan, before I build anything. Everything below is an imaginary plan, made with the help of AI tools. The real build will change it, step by step. Real hardware, photos and measured results start from post #2.
Please read first: this is my dream project, shown as an imaginary plan
EcoMate is a project I really need for my own lab, and this post shows my dream version of it. The plan was put together with the help of AI tools, and the diagrams are early plan sketches, not the final design. The real design and build will change, sometimes a lot, as I test and improve every step. This is my first attempt at a robot like this, and with the contest time frame I may not finish every feature. What will not change is the core idea: collection, separation, sorting and arrangement. If something does not work as planned, I will show it and explain what I changed.
The problem
After every project, LEDs, resistors, capacitors, diodes and wire cuttings end up scattered on my desk and floor. Useful parts get mixed with waste, cleanup takes a long time, and good parts are often lost or thrown away. This happens after every project.
  • Goal: keep the lab clean and recover reusable parts, semi-autonomously.
  • Success metric: the number of "parts saved from the trash", counted by the robot itself.
That is why EcoMate fits "My Project is Trash": it saves reusable parts from the trash, right where the trash is made.
The idea: a recycling plant in miniature
Real recycling plants do not sort everything in one step. They collect the waste, a big magnet pulls out the metal, and then cameras and robot arms pick the rest. EcoMate puts the same three stages on one small horizontal robot:
Stage 1 SWEEP → Stage 2 MAGNETIC LIFT → Stage 3 SEE AND PICK
3 stages
"Navigate a small workshop, detect scattered objects and collect lightweight items"
  • A 4-wheel-drive chassis with geared DC motors, built around the Hammond box.
  • An overhead camera on an arch looks at the floor ahead, so EcoMate can see a mess before it drives over it.
  • A front roller brush and a ramp throw items into a pull-out trash drawer. I chose a brush, not a vacuum: a vacuum would swallow the small parts I want to save, it is loud, and it needs a lot of power.
  • Bumps and a jammed brush are detected by the ADXL372 (see the kit table below).
"Wire offcuts are collected separately"
Here I plan to use physics before AI. Many component legs contain steel. Copper wire offcuts, insulation and dust do not.
  • An electromagnet on a vertical column goes down through an opening in the deck, into the trash drawer.
  • It switches on, rises, swings over a white tray on the upper deck, and switches off. Only steel-leg parts come up.
  • Copper wire offcuts, insulation and dust stay in the drawer. The drawer is the waste compartment, and I empty it separately.
The magnet is home-made: enamelled copper wire wound on a steel bolt, driven by a current-limited supply so it cannot overheat, with a diode to protect the switch. A coming post measures exactly which lab waste sticks to a magnet, so this stage is designed from real numbers.
"Recognise component categories with a camera and direct them into storage compartments"
  • If parts touch each other, the arm first pushes them apart with its closed gripper, and the tray-tilt servo can give a quick shake. No extra motor is needed.
  • The camera looks down at the tray. The main controller (Python and OpenCV) finds one part lying on its own and classifies it by colour, size and shape.
  • A SCARA arm with a small printed tweezer gripper (soft TPU tips) picks that one part and drops it into its box:
LEDs (8/10 mm) · Capacitors (large) · Resistors (big, 1–5 W) · Diodes (big)
These are the same part families my abstract describes: "LEDs, resistors, capacitors, diodes and wire cuttings scattered across my workspace and floor." For this project I deliberately use the bigger versions: 8 mm and 10 mm LEDs, large electrolytic capacitors, 1–5 W resistors and big power diodes. A small printed gripper can hold them reliably, and the camera can see them clearly. Tiny parts (like 1/4 W resistors) are out of scope for this version. I prefer to promise less and show it working.
"Uncertain items go to an inspection tray, so valuable parts are not discarded"
  • The white tray is the inspection tray. If the camera is not confident about a part, the arm leaves it there.
  • EcoMate then stops, makes the red Sort lights blink slowly, and the web app shows me the photo of that part. I check it and take it by hand.
  • Only after I confirm does the tray tilt, and the remaining non-component bits (mostly plastic the magnet carried up by mistake) fall back into the drawer.
  • So an unsure part is never thrown away automatically. A slow sort is better than losing a good part.
How each sponsored kit part is used
Kit part My abstract said Detailed plan
ADI EVAL-CN0569-PMDZ (IR light-angle sensor) optical direction / object-position sensing "Come here" mode: it measures the angle to a small IR beacon that I place near a mess, and EcoMate steers toward it
ADI EVAL-ADXL372Z (3-axis accelerometer) impacts, abnormal vibration, tipping Bump detection, a jammed brush (the vibration changes), and tilt safety. I will report how well a ±200 g shock sensor handles slow tilt
Hammond 1554X2GYCL IP68 enclosure protect the control electronics It becomes the robot's base, with the battery and electronics inside. This gives a low centre of gravity and a clear "engine room" window
CamdenBoss green / amber / red indicators (9) operating, processing, fault The colour shows which stage is working: green = Stage 1 Sweep, amber = Stage 2 Magnetic separation, red = Stage 3 Arm sorting. Steady = running, slow blink = waiting for me (for example a part on the inspection tray), fast blink = fault. Only one stage runs at a time, so the 3 lights of each colour are wired in parallel and need only 3 pins
CamdenBoss pluggable terminal blocks (3 + 3) organized electrical connections One 4-way connector per stage, so each stage unplugs as a module
CamdenBoss microswitches (2) end position + bin monitoring #1: trash drawer full. #2: magnet lift home position
"Combine with my own microcontrollers, motors, drivers and servos"
  • Main controller: the brain. It runs the vision, web app and voice, plus the arm and the ADI sensors.
  • A helper I/O board, so the main controller never runs out of pins: a second microcontroller takes commands from the main controller and drives all three stages (wheels, brush, magnet lift, coil relay, swing servo, tray tilt), the 3 light lines and both microswitches.
  • Motion and power: geared DC motors for driving and the brush, a small stepper for the lift, and hobby servos for the arm, magnet swing and tray. A rechargeable battery feeds separate regulated supplies for the logic, the servos, the motors and the magnet, so a motor can never reset the brain.
  • Camera: a USB camera on the arch.
  • Printing: everything printed on my Bambu Lab A1 (rigid filament for the structure, flexible TPU for the brush fins and gripper tips).
Control: semi-autonomous AUTO mode (sweep, lift, sort), manual control of each stage, a phone web app with live camera view and the "parts saved" counter, and simple voice commands ("start", "stop", "come here"). EcoMate never sweeps and sorts at the same time: sorting happens while it is parked, so the camera image is sharp.
"Begin with movement, collection and safety, then sensing and sorting"
I will build EcoMate as three separate modules. Each one must work and pass its own tests on the bench before it joins the robot.
Module What it does Tested on its own by
Sweep Drive, brush and ramp into the trash drawer Driving over a known mix of parts and wire offcuts, and counting what ends up in the drawer
Magnetic separation Magnet lift from the drawer to the white tray Running lift cycles over a full drawer, and counting which parts come up and which stay behind
See and pick Camera, arm and the four boxes Placing parts on the tray by hand, and counting correct picks, wrong boxes and parts left for inspection
Then the modules are joined step by step, and every step gets tested again:
  • Sweep + magnet: sweep, then lift. Does the magnet still work on a real, messy drawer?
  • Sweep + magnet + arm: the full chain, run one stage at a time in manual mode.
  • Full AUTO: start, sweep, lift, sort and stop without help. Then the web app, voice and safety stops (bump, tilt, drawer full).
  • Repeat: run the whole cycle many times, fix the weak points, and run it again.
Each forum post will show one of these steps with real results.
"Document the real performance and limitations"
My abstract promised to report what really works, not only what I hoped. So each post will show real results, including what failed. Three things I am not sure about yet:
  • Collection: will the brush pick up small parts from a real floor?
  • Separation: the magnet only lifts parts with steel legs, so some parts will stay in the drawer.
  • Sorting: the camera can confuse similar-looking parts, and it cannot tell if a part still works. Unsure parts wait on the tray for me.
What's next?
The next step is building the base: the chassis around the Hammond box with the four wheels and motors, so EcoMate can drive on the floor.
After that, I will:
  • Add the roller brush and the trash drawer, and test how much it really collects.
  • Test which lab waste actually sticks to a magnet, before I wind the electromagnet.
  • Take the first readings from the ADXL372 and the CN0569.
