N-gaged Design Challenge
  • N-gaged Design Challenge
N-Gaged Blog Solution --- If your having trouble connecting your Gateway to the internet - THIS MIGHT HELP
  • Author Author: skruglewicz
  • Date Created: 11 Apr 2022 9:47 PM Date Created
  • Views 3038 views
  • Comments 12 comments
skruglewicz
skruglewicz
11 Apr 2022
Hello Fellow challengers of the OMEGA  N-Layer Design challenge.
If you are having troubles as I and a fellow challenger guillengap , with getting the Gateway from the bundle to connect to the internet, this blog might help.
I contacted Omega support via email and after several conversations back and forth and a few days, they came up with the following instructions that did the trick for me. After following the steps below, by putting the recommended firmware onto the gateway I was able to connect it to the internet and continue attaching the rest of the components to it.  I’m sure it will affect more of you because my out of the box gateway had a really old firmware version. I posted this blog to help my fellow challengers avoid the time I spent, trying to get the major hardware component of the bundle to work.
How to fix No Network/Internet Connection for Out-of-Box Gateway
Troubleshooting
You have a brand new, out-of-box Layer N gateway. You already created a Layer N account from the
cloud.omega.com. You are ready to connect the gateway to your Internet-enabled router with a
network cable.
However, after many tries to connect to the Internet and you are sure that your router does have
Internet connection, but your gateway ‘s LED light is still on either Solid Orange or Flashing Red.
Recommended Solution
You need to manually update your gateway firmware.
Here are the Steps:
  1. Access Gateway Internal Web UI – Please read enclosed Quick Start Guide
  2. Download the firmware:
If you have GW-001-2, please download your firmware at
https://omegaupdates.azurewebsites.net/Firmware/GW/gw-001-2-na_v1.0.25.bin
If you have GW-001-3, please download your firmware at
https://omegaupdates.azurewebsites.net/Firmware/GW/gw-001-3-na_v1.0.24.bin
  1. From the Gateway web UI, please navigate to the System Settings page
  2. Click on the magnify icon to browse the firmware file you just downloaded on your computer.
  3. Click Upload to get the latest firmware on your gateway. Please wait a few seconds for gateway to
Install the firmware and reboot itself.
My out of box settings
Current Firmware Version:1.0.5, Release Date:28, May, 2020
SO much out of date!!
SUCCESS with the process !! hooray!!
After following the instructions, the LED is now solid green !!!
My settings screen shows Current Firmware Version:1.0.24, Release Date:27, Jul, 2021
A new option under settings “LOG”, shows the connection!
The n-layer cloud shows the heart beat Icon and the (i)information icon displays the connection status
Now you proceed with connecting the Smart Sensor
Enjoy
Appendix A – Understanding the behavior of the LED light on the gateway
This pdf was emailed to me by Tech support. It defines the different LED status codes, rebooting and setting the gateway to the  factory resets
  • scottiebabe
    scottiebabe over 4 years ago +1
    Kudos to you for working through a strange issue and blogging about the solution.
  • guillengap
    guillengap over 4 years ago +1
    Your solution is reasonable and I will try it! I hope the sponsor rewards your effort! Kind regards
  • scottiebabe
    scottiebabe over 4 years ago in reply to skruglewicz +1
    Yes fortunately mine worked right out of the box :) My unit was shipped with the following firmware: Take care,
  • guillengap
    Kind regards
  • guillengap
    Kind regards
  • skruglewicz
    skruglewicz over 4 years ago in reply to guillengap
    Hello guillengap,
    Thank you so much for commenting to my blog
    Tech support came up with the solution. They gave me the link to the most recent firmware version that worked with a major function of the gateway, that is "connecting to the internet". They provided good product support for a problem that in my option,  should be noted in the getting stating guide.  If you have an MCU in your so called PlugAndPlay device, there should be a diagnostic section to help when things don't work properly.
    Note to OMEGA Product Support: it would be nice to know what the latest Firmware version is and where to get it. What took me 10 minutes to resolve, took a span of of 5 days to get a resolution. Oh well I'm glad I didn't have a boss breathing down my neck to implement this.
    Let me know if this solution works for you OK? and if you can reveal what firmware version you have on your gateway. Out of the box.
    Looking forward to a very interesting Design Challenge.
  • guillengap
    guillengap over 4 years ago in reply to skruglewicz
    I already flashed my Gateway, and it has an internet connection... now I have two small issues: 1) sometimes the Gateway disconnects unpredictably, and 2) I haven't been able to pair the SS-002-1-NA module... Have you had any problem?
  • skruglewicz
    Hello I seem to recall a little spurt of the gateway disconnecting but no problems now. I did wait a few minutes until the gateway ettled down and then paired it with no problem.
