On the Line
  • On the Line
On the Line
Forum Technical Support Thread | On the Line Design Challenge
  • News
  • Projects
  • DC
Join On the Line to participate - click to join for free!
  • Subscribers 37 subscribers
  • Views 297 views
  • molex
  • On the line design challenge
  • adi
  • e14-on-the-line
  • omega
  • analog devices
JoRatcliffe
JoRatcliffe 6 months ago
With the challengers announced and kits soon to be arriving, I thought it would be a good time to create somewhere for any questions on the kit that I can forward to suppliers or for discussing challenges and solutions relating to the kit.
This is potentially just a starting point, anyone is very welcome to share additional links or resources that you think everybody would benefit from.
Links & Documentation
Product URL for Reference Manufacturer Part Number Documentation
https://uk.farnell.com/analog-devices/max33041eshld/shileld-eval-kit-can-transceiver/dp/3807530
MAX33041ESHLD#
Technical Data Sheet
https://uk.farnell.com/omega/5srtc-tt-k-24-72/thermocouple-type-k-2m-260deg/dp/3795213
5SRTC-TT-K-24-72
https://uk.farnell.com/omega/hx94c/humidity-sensor-current-30v-w/dp/3463003
HX94C.
https://uk.farnell.com/molex/218112-0202/cable-assy-rcpt-free-end-225mm/dp/3783585
218112-0202
Drawing
https://uk.farnell.com/molex/218112-0300/cable-assy-rcpt-free-end-75mm/dp/3783588
218112-0300
Drawing
https://uk.farnell.com/molex/218112-0500/cable-assy-5pos-rcpt-free-end/dp/3776605
218112-0500
Datasheet
Drawing
https://uk.farnell.com/molex/218112-0602/cable-assy-6pos-rcpt-free-end/dp/3776614
218112-0602
Drawing
https://uk.farnell.com/molex/218112-0703/cable-assy-rcpt-free-end-300mm/dp/3783614
218112-0703
Drawing
https://uk.farnell.com/arduino/abx00162/uno-q-sbc-2gb-arm-cortex-a53-m33f/dp/4808383
ABX00162
Files and documents shared here are correct as of 29th April 2026 and is intended as a 'snapshot in time'.
  • skruglewicz
    skruglewicz 6 months ago +1
    Hi JoRatcliffe Thank you so much for putting this technical support thread together! Having a centralized "snapshot" of the kit components, complete with direct links to the data sheets and manufacturer…
  • skruglewicz
    Hi JoRatcliffe
    Thank you so much for putting this technical support thread together! Having a centralized "snapshot" of the kit components, complete with direct links to the data sheets and manufacturer part numbers, is an incredible reference for all of us participating.
    I usually kick off my design process by building a personal outline and conducting deep-dive research into each part of the sponsor kit. Having all these resources organized in one place right at the start is a huge time-saver and a great foundation for the research phase.
    Looking forward to getting started with the kit!
    Best, Stephen (skruglewicz)
  • arvindsa
    arvindsa 5 months ago
    JoRatcliffe  been running to a problem. I tried quite a lot to run the CAN controller of the STM32 on the ArduinoQ but it is not working, as per the links
    forum.arduino.cc/.../1414493
    forum.arduino.cc/.../1416035
    https://forum.arduino.cc/t/trying-to-get-fdcan-working-on-the-uno-q/1431867
    its not supported by the ArduinoQ as of now. Any connect to the Qualcomm to have a confirmation on this?
