Path II Programmable
  • Path II Programmable
Blog usb Webcam for Ultra96V2
  • Author Author: buffteethr
  • Date Created: 25 Nov 2019 6:25 PM Date Created
  • Views 1364 views
buffteethr
buffteethr
25 Nov 2019
Can anyone suggest a cheap usb webcam for the Ultra96V2 that has drivers for petalinux? I need it for my final project.
Thanks,
Cary
  • Sean_Miller
    Sean_Miller over 6 years ago +1
    Here's a $9 one. I've tested this one on Linux and Windows. No need to install drivers. It's 640x480 with manually adjustable focus. https://www.amazon.com/gp/product/B00OB883F6/ref=ppx_yo_dt_b_asin_title_o02_s00…
  • ralphjy
    ralphjy over 6 years ago +1
    I've also tried a couple of Logitech cameras (C525 and C922) with the Ultra96v2 with both Ubuntu (Pynq) and PetaLinux. I'm currently using the C525 (use the C922 on my Windows box). I guess you need to…
  • ralphjy
    I've also tried a couple of Logitech cameras (C525 and C922) with the Ultra96v2 with both Ubuntu (Pynq) and PetaLinux.  I'm currently using the C525 (use the C922 on my Windows box).  I guess you need to determine what resolution, frame rate, and other features (auto-focus) that you want.  The C525 seemed about the right compromise for cost but it is an older camera that I bought a couple of years ago.  I'd probably get a C615 today.  I've had reasonable luck with Logitechs but YMMV.  For lower resolution you can't get much lower cost than what Sean recommended.
  • ralphjy
  • buffteethr
    buffteethr over 6 years ago in reply to ralphjy
    THanks Ralpha. I order the C525 since I noticed you got it to work in one of our Pynq implementation.
