Path to Programmable 3
  • Path to Programmable 3
Blog Extensive usage of XADC module on MiniZed Starter Kit
Join Path to Programmable 3 to participate - click to join for free!
  • Author Author: svnagendra2003
  • Date Created: 4 Sep 2023 4:12 PM Date Created
  • Views 760 views
svnagendra2003
svnagendra2003
4 Sep 2023
  • svnagendra2003
    svnagendra2003 over 3 years ago
    Final Project
    Extensive Use of XADC module for Sensor data acquisition/Power measurement using MiniZed board
    Create new project
    Select the device as XC7Z007Scfg225-1 which is the SoC available on MiniZed board
    Click on create block design
    Type XADC and select XADC wizard
    Right click on Vp_Vn pin and click Make external
    Add clocking wizard block
    Click on Run connection automation
    Connect clk_out1 and Locked outputs of the CLK_WIZ_0 to the s_axi_aclk and s_axi_aresetn pins
    Double click on XADC_WIZ_0 module and enter the different ADC parameters
    Click on Create HDL Wrapper
    Click on Implementation and Then Create Bitstream
    Then open Hardware Manager
    Double click on XADC (System Manager)
    In XADC dashboard, add all XADC signals
    All the ADC signals can be added and probed as shown in figure below
    External analog signals can be connected to the AD0 to AD5 pins and the changes can be seen over this XADC monitor
