Path to Programmable 3
  • Path to Programmable 3
Forum Training [2021.2] : Software : LAB 4 : Create Application Project Error
Join Path to Programmable 3 to participate - click to join for free!
  • Subscribers 128 subscribers
  • Views 1300 views
  • avnet
  • ultra96
prashanthgn.engineer
prashanthgn.engineer over 3 years ago
Dear Path to Programmable 3 Challengers
Request you to support on the below error
I am Stuck at Lab 4
Regards
Prashanth Kumar G N
  • javagoza
    javagoza over 3 years ago
    Which version of Vitis are you using? Could it be that you were not using the same version of Vitis as the one that was intended for that BSP?
  • saadtiwana_int
    saadtiwana_int over 3 years ago
    This looks like a bad VITIS installation. If nothing else works, I would suggest doing a fresh reinstall of VITIS.
  • javagoza
    javagoza over 3 years ago in reply to saadtiwana_int
    standalone 7.5 refers to the BSP Standalone OS Library version.
    Version 7.5 is for version 2021.1
    https://docs.xilinx.com/r/2021.1-English/oslib_rm/Standalone-Library-v7.5
  • saadtiwana_int
    saadtiwana_int over 3 years ago in reply to javagoza
    Did this lab involve creating a new project from scratch or opening an existing project?
    If it's the former, then my thinking is that Standalone OS should come packaged in the installation.
    If it's the latter (opening an existing project then it could be an out-dated reference or something like that).
    Anyway, just some guesses...I'm no expert by any means. I would listen to javagoza more than myself! Slight smile
  • prashanthgn.engineer
    prashanthgn.engineer over 3 years ago in reply to javagoza
    Hello  javagoza
    Its Vitis 2021.2
  • navadeepganeshu
    navadeepganeshu over 3 years ago
    You can once open the built project from the solutions folder and check if the tool installation is proper and project platform dependencies are linked.
