Path to Programmable 3
  • Path to Programmable 3
Forum not able to read UART port using putty
Join Path to Programmable 3 to participate - click to join for free!
  • Replies 14 replies
  • Subscribers 128 subscribers
  • Views 6452 views
  • zynq
  • ultra96
  • Path Programmable III
manojroy123
manojroy123 over 3 years ago
the usb to JTAG/UART pod is not able to read UART port using puTTY terminal. Not able to figure out what is going on.
can anyone help me in solving this problem. the board I am using is Ultra96-v2
  • manojroy123
    manojroy123 over 3 years ago +2
    The puTTY problem was solved by letting Ultra96 boot run in SD card mode with Linux install in it. After that the puTTY terminal was picking data from UART port of Ultra96-v2 development board.
  • manojroy123
    manojroy123 over 3 years ago in reply to javagoza +1
    thanks for the help puTTY serial port problem was solved
  • javagoza
    javagoza over 3 years ago in reply to javagoza
    Vitis has a built in serial terminal included in its Debug view. Close any putty windows and from Vitis using the search field look for Serial Terminal, create a new one and adjust com and baud rate.
    Then try to program your board.
    In my case I have problems with JTAG if I have connected my Digilent Analog Discovery II that has an Spartan 6. I have always need to disconnect it before programming the minized.
  • manojroy123
  • manojroy123
  • taifur
    taifur over 3 years ago in reply to manojroy123
    That's great.
