Path to Programmable 3
  • Path to Programmable 3
Forum not able to read UART port using putty
Join Path to Programmable 3 to participate - click to join for free!
  • Replies 14 replies
  • Subscribers 128 subscribers
  • Views 6450 views
  • zynq
  • ultra96
  • Path Programmable III
manojroy123
manojroy123 over 3 years ago
the usb to JTAG/UART pod is not able to read UART port using puTTY terminal. Not able to figure out what is going on.
can anyone help me in solving this problem. the board I am using is Ultra96-v2
  • manojroy123
    manojroy123 over 3 years ago +2
    The puTTY problem was solved by letting Ultra96 boot run in SD card mode with Linux install in it. After that the puTTY terminal was picking data from UART port of Ultra96-v2 development board.
  • manojroy123
    manojroy123 over 3 years ago in reply to javagoza +1
    thanks for the help puTTY serial port problem was solved
  • javagoza
    javagoza over 3 years ago
    It is very strange though that a USB device appears to you as COM3 or COM4. Can you put two screenshots of the Ports (COM & LPT) section of your Device Manager with the device connected by USB and with the device disconnected?
    Also set the speed to 115000 bauds instead of 9600 bauds
  • manojroy123
    when device connected
    when device disconnected
  • manojroy123
    the speed is set to 115200 bauds
  • Gough Lui
    Gough Lui over 3 years ago
    Please make sure your baud rate is set correctly, also worth setting the flow control to None.
  • javagoza
    javagoza over 3 years ago in reply to manojroy123
    With the usb plugged try to uninstall the device,
    Then, once uninstalled plug the USB cable in another USB port
    I think you don't need to install any drivers for the FTDI USB-to-UART bridge
  • manojroy123
    only get one data bit as shown in image bellowimage
  • javagoza
    Press reset on the board and if you still see strange characters review PuTTY Configuration for com4 as suggested  Gough Lui
  • javagoza
    javagoza over 3 years ago in reply to javagoza
    If you are testing with putty and the JTAG selected your are not going to see anything until you program the board I think
  • manojroy123
    please check the bellow video. In it, they have shown that you can access UART in JTAG boot mode via puTTY terminal. The SD card already has linux install in it.
  • javagoza
    Yes, what I say is if you haven´t programmed anything that sends data through the uart you  are no going to see anything
