Path to Programmable 3
  • Path to Programmable 3
Forum question about petalinux installation
Join Path to Programmable 3 to participate - click to join for free!
  • Subscribers 129 subscribers
  • Views 1239 views
  • petalinux
  • ultra96
  • Path Programmable III
  • amd
  • installation
manojroy123
manojroy123 over 3 years ago
I have a windows 8 computer the bellow documents states the installation requirement for petalinux. In it they haven't mentioned any information regarding installation of linux in windows environment. Does anyone knows how to install petalnux in windows enviornment
  • saadtiwana_int
    saadtiwana_int over 3 years ago +2
    You cannot install Petalinux in windows. You need a linux host. If you have windows installed on your system, you need to use virtualbox or vmware to get a linux installation. This is what is done in the…
  • saadtiwana_int
    You cannot install Petalinux in windows. You need a linux host. If you have windows installed on your system, you need to use virtualbox or vmware to get a linux installation. This is what is done in the Training course from AVNE, if you follow it from the start.
    shabaz over 3 years ago
    Windows 8 was ancient years ago, and it's risky if you're using it because it no longer even receives Windows updates as far as I'm aware. If AMD software is running on it, you've been lucky so far, but it's complicated enough software that you may well experience issues.
    Definitely worth moving to Linux, or at least Windows 10 (or Windows 11).
