Hello
I m participant in PP3, tomorrow is last date.
When I uploaded 1.4Mb text in it, and opened to re-edit, it stucks here, below is error
pls urgently correct it
By mistake, its twice pasted, also, I have to add content below of it.
Hello
Thanks, Shabaz
but I dont have capability to choke site, people do have & had exercised on me.
No, even if i remove this new data, it gave that error. Yes, too many pics
Anyway. Thanks
Pl correct it
You can correct your approach of posting, without need for urgent forum changes. We've given solutions.
let it open, will remove dataset, but it is not opening , Opening only like Ist pic.
Zip solution by you will be winner but even the other new blog without dataset is not opening smoothly. It is opened after time.
Urgent changes would be there as i type here only.
Maybe start a fresh post?
1st enter unformatted text
Then format
Then add reasonable size images, via upload (not copy paste)
Add snippets of the data file
Upload full datasets as zip
Save as draft often.
edit: there are a few days extra to finish your post: RE: Path to Programmable 3 - Extension for Posting the Final Project Blog -- New Due Date Sept 5, 2023
Hi abhishek2018
If you're getting errors such as these, we need to know about them in Feedback and Support , report them as a problem with details such as what you were doing at the time it happened or just before. Errors such as this typically mean you've been caught by the website anti-bot protections, usually you can resume what you were doing after about 10 minutes.
Hello cstanton
I knew as you had earlier pointed out but posted here intentionally as worried on last date and so that failure to submit on 29, is clearer to sponsor .
I didnt posted there as it would be duplicate post.
has found out cause of this problem
Oh good, thanks for letting me know. Please do make that clear on the thread by going to the post or posts that helped, and clicking the 'more' option and marking as 'suggest as answer' or 'verified answer' so that we know it's resolved.
there are 3 suggestive answers.
one by Shabaz, one by Jan Cumps, one by you.
Can i select all 3, lets try
