Pi-Fest
  • Pi-Fest
Pi-Fest
Blog Blog# 3 Testing -- Pi Fest - Music/Audio Project
  • Author Author: skruglewicz
  • Date Created: 22 Jul 2022 7:06 AM Date Created
  • Views 717 views
skruglewicz
skruglewicz
22 Jul 2022
imageBlog#3 Testing- Music/Audio Projectimage
 This blog is part of a blog series for the Pi-Fest Design Challenge.
 This blog will describe the unit testing I performed on the 4 electronic components that I attached to the PICO. The Wiring diagram and the code for each of the 4 components that I will attach to the PICOis depicted in this blog. I then used the code to implement my design code.
UNIT Testing
  • PICO to Display
    • This test will display 100 on the SSD1306 OLED screen along with a title.
  • Wiring
    • image
  • CODE
    • from machine import Pin, I2C
      import ssd1306
      # setup the I2C communication
      i2c = I2C(0, sda=Pin(16), scl=Pin(17))
      display = ssd1306.SSD1306_I2C(128, 64, i2c)
      bpm = 100
      # The following part changes according to what you want to display
      display.text('Beats Per Minute,', 0, 0)
      display.text('----------------', 0, 16)
      display.text(str(bpm),50, 32)
      display.text('----------------', 0, 48)
      # The following line sends what to show to the display
      display.show()
  • PICO To Buzzer
    • This test will turn the Grove buzzer on and off.
  • Wiring
    • image
  • CODE
    • # Active Buzzer that plays a note when powered
      from time import sleep
      from picozero import Buzzer
      buzzer = Buzzer(18)
      buzzer.on()
      sleep(1)
      buzzer.off()
      sleep(1)
      buzzer.beep()
      sleep(4)
      buzzer.off()
  • PICO to LED
    • This test will blink the Grove LED every half second.
  • Wiring
    • image
  • CODE
      led = Pin(13, Pin.OUT)
      while True:
          led.toggle()
          sleep(0.5)
  • PICO to Potentiometer
    • This test will print the Potentiometer value on the PC serial port.
  • Wiring
    • image
  • CODE
    • from picozero import Pot # Pot is short for Potentiometer
      dial = Pot(0) # Connected to pin A0 (GP26)
      while True:
          print(dial.value)
          sleep(0.1) # Slow down the output
References
This section includes some links that I found helpful.
picozero API — picozero 0.2.0 documentation
    DAB over 4 years ago +1
    Nice overview of the parts.
