Pi-Fest
  • Pi-Fest
Pi-Fest
Blog Blog#4 Implementation-- Pi Fest - Music/Audio Project
  • Author Author: skruglewicz
  • Date Created: 22 Jul 2022 7:14 AM Date Created
  • Views 867 views
skruglewicz
skruglewicz
22 Jul 2022
imageBlog#4 Implementation-- Pi Fest - Music/Audio Projectimage
 This blog is part of a blog series for the Pi-Fest Design Challenge.
  • This blog will include the details of the implementation of my idea. A Video and photo's are used to show metronome working as designed
Firmware Implementation
This section will describe my implementation of the Firmware that will run on the PICO for my metronome Idea.
FIRMWARE CODE
from picozero import Pot, LED, Buzzer # Pot is short for Potentiometer Add LED
from time import sleep
# OLED
from machine import Pin, I2C
import ssd1306
dial = Pot(0) # Connected to pin A0 (GP26)
led = LED(13) # Make sure this is the correct pin
buzzer = Buzzer(18)
# OLED
# setup the I2C communication
i2c = I2C(0, sda=Pin(16), scl=Pin(17))
display = ssd1306.SSD1306_I2C(128, 64, i2c)
heart_min = 40
heart_max = 180
heart_range = heart_max - heart_min # Calculate the difference
#bpm = 0
while True:
    bpm = heart_min + dial.value * heart_range # Convert dial value to BPM
    print(int(bpm))
    # The following part changes according to what you want to display
    display.text('Beats Per Minute,', 0, 0)
    display.text('----------------', 0, 16)
    display.text(str(int(bpm)),50, 32)
    display.text('----------------', 0, 48)
    display.show()
    beat = 60/bpm
    brighter_time = beat / 2 # Spend half a beat getting brighter
    dimmer_time = beat / 2 # Spend half a beat getting dimmer
    print(brighter_time)
    print(dimmer_time)
    #led.pulse(brighter_time, dimmer_time, n=1, wait=True)   # Pulse 1 time, waiting until finished
    sleep(brighter_time)
    #display.poweron()
    led.on()
#     buzzer.beep(brighter_time, dimmer_time, n=1, wait=True)
    buzzer.beep(.10, .25, n=1, wait=True)
    #display.text(str(0),50, 32)
    #display.poweroff()
    led.off()
    sleep(dimmer_time)
Hardware Implementation
This section will describe the implementation of the circuit using the Pico and other electronics, to implement my metronome idea.
image   image    image
VIDEO
References
This section includes some links that I found helpful.
    DAB over 4 years ago +1
    Keep the beat going.
