Pi IoT
  • Pi IoT
Pi IoT
Blog IoT Farm: Blog 15 - F.O.C. followup.
  • Author Author: jkutzsch
  • Date Created: 30 Aug 2016 1:19 AM Date Created
  • Views 1789 views
  • Comments 7 comments
  • piiot
  • farm
  • farm_technology
  • pi iot design challenge
jkutzsch
jkutzsch
30 Aug 2016
Going through my previous blog entries I realized I had not provided the followup information for my Farm Operations Center Box that I had previously said I would.
So here it is!  :-)
As I had mentioned before the medium sized box worked perfectly as a container for the 7 inch touchscreen with Pi3 attached.
As you can see here, the 4 squares line up perfectly with the metal frame of the touchscreen.  Making for an easy mounting of the F.O.C. to the plastic container.
Here we have the view of Camera 2 moved over to monitor the Duck Domain.  With an easy swipe of a finger up or down I can look at any of the camera feeds!
From my top picture above you can see there is a good amount of space available to mount additional items including but not limited to batteries.  I had came across a very interesting sounding battery option with pass through capabilities advertised at Best Buy that I wanted to try.  Of course when I arrived there to purchase it there was none to be found.  Online it listed 3 in inventory, even the stores internal inventory listed 1, but after an hour of waiting and searching through Best Buy I ended up heading over to Walmart again to pick up a small usb battery.
Sadly the idea of pass through charging only seems of interest to those with cell phones.  Trying to explain to various techs what exactly I needed in a battery led to a lot of confused looks and nothing that helped me for this project.
You would think the idea of having a power source that can charge your phone/tablet/micro usb item while also charging the battery would be a great thing to have.  Why bring a charger and a battery if you battery can also charge your device while charging itself?  Obviously a pass through battery would be quite nice to add into the F.O.C. box so I could just quickly pull the cord and head out to check things without having to power down and restart with the battery.
I did end up picking up a basic 4400 mah battery with the idea of testing, but while I was assured it had a 2.1 amp output the RPi3 with 7 inch screen was not impressed with its actual power providing and refused to work with just that battery.  So caveat to others, keep your receipts and packaging.
Once I do find a pass through battery that works for my setup I will share out to Element 14.
  • pettitda
    pettitda over 10 years ago +1
    Check out this guy for charging and boosting a LiPo battery to 5V: https://www.sparkfun.com/products/11231
  • pettitda
    Here's another one: https://www.adafruit.com/product/1944
  • fvan
    fvan over 10 years ago in reply to jkutzsch +1
    Backed the Kickstarter version, have yet to see some good news and get it in my hands *fingers crossed*
  • jkutzsch
    jkutzsch over 10 years ago in reply to fvan
    I need to monitor Kickstarter more!  I always seem to come across them as news announcements of them already meeting their goals and now everyone is waiting for shipments!  fvan, please share out your experience once you get one to work with!
  • fvan
    Backed the Kickstarter version, have yet to see some good news and get it in my hands image *fingers crossed*
  • jkutzsch
    jkutzsch over 10 years ago in reply to pettitda
    PiJuice sounds very interesting from what I have been able to read about it.  I like the solar tie in as well.
    Let's hope for them to work with Element14 in getting their product out and maybe seeing some Roadtests!
    element14Dave  ;-)
  • jkutzsch
    jkutzsch over 10 years ago in reply to jkutzsch
    Here is the currently promising $8.99 option:
    https://www.amazon.com/gp/product/B017LTYPGC/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
    2.1A with pass through charging and it fits right next to the lcd cabling in the FOC box.  With a little Velcro to secure it, it seems to be a viable option.
    I have been able to use the RPi and Touchscreen without any problem, now just need to do some testing to see if pass through truly works and what kind of life 5000 mAh gives me.  :-)
    On the Connecting Santa To the IoT thread I am hoping to work with another larger 20000mAh battery option with 3 power ports.  But still waiting for the RPi boards to come in for that project.  Or I may need to cannibalize some other projects.  :-)
    https://www.element14.com/community/community/events/tistheseason/blog/2016/01/28/connecting-santa-to-the-iot-winner-announcement
  • jkutzsch
    Do you think this would be powerful enough to run an RPi and Touchscreen installation?  I was assuming I would need something closer to 2 amps.  I tried out a generic battery that claimed 2amp output from Walmart, it failed miserably.  But I am testing another with pass through charging claims that so far looks good!
