PiCasso Design Challenge
  • PiCasso Design Challenge
Blog Big Entrance Part 1
  • Author Author: armour999
  • Date Created: 22 May 2019 10:12 PM Date Created
  • Views 1120 views
Big Entrance Part 1
armour999
armour999
22 May 2019
I have FEM and Enocean Pi up and running. I installed the reed sensor above the door so when the door is opened a telegram will be sent to FHEM.
I have a small monitor to display the sketch. I am going to mount it above the counter using Velcro. This will prevent the monitor and Raspberry Pi from being pushed to the floor .
Below is a simple test of a processing sketch.
I will be testing a python script to-morrow to trigger the script from the Raspberry Pi with Enocean Pi installed when a door is opened to connecting to the Raspberry Pi 3+. To use a remote script I will be including the following code:
import subprocess
subprocess.open("ssh pi@<static ip> 'cd ~ && python your_script.py'", shell=True)
    dubbie over 7 years ago +3
    That's different. Is it your eyeball? Dubbie
  • armour999
    armour999 over 7 years ago in reply to dubbie +3
    Sorry I was hitting publish too soon. Hope to test the code to-morrow. I know the clock is ticking.
    Dubbie
  • armour999
  • armour999
