PiCasso Design Challenge
  • PiCasso Design Challenge
Blog Smart Home Orchestra And Mood Mediator (SHOAMM) - Troubleshooting TensorFlow and Magenta in Docker
  • Author Author: vlasov01
  • Date Created: 26 May 2019 11:57 AM Date Created
  • Views 553 views
  • tensorflow
  • magenta
  • python
  • picasso
  • avx
  • midi
vlasov01
vlasov01
26 May 2019
Debug
I've executed python commands in interactive mode to identify where it fails:
root@05e99fc1ad94:/usr/local/bin# python
Python 2.7.12 (default, Dec  4 2017, 14:50:18)
[GCC 5.4.0 20160609] on linux2
Type "help", "copyright", "credits" or "license" for more information.
>>> import re
>>> import sys
>>> from magenta.models.melody_rnn.melody_rnn_generate import console_entry_point
Illegal instruction (core dumped)
So is it failed because of Magenta ot TensorFlow?
>>> import re
>>> import sys
>>> import tensorflow as tf
Yes, it failed in TensorFlow.(1.10.0)
As per https://github.com/tensorflow/tensorflow/issues/17411 and https://superuser.com/questions/1398548/your-cpu-supports-instructions-that-this-tensorflow-binary-was-not-compiled-to-u…   starting TF 1.6 it is using AVX CPU features. And CPU I have doesn't support AVX instructions.
tf@ubuntu:~$ lscpu
Architecture:          x86_64
CPU op-mode(s):        32-bit, 64-bit
Byte Order:            Little Endian
CPU(s):                8
On-line CPU(s) list:   0-7
Thread(s) per core:    1
Core(s) per socket:    4
Socket(s):             2
NUMA node(s):          1
Vendor ID:             GenuineIntel
CPU family:            6
Model:                 46
Model name:            Intel(R) Xeon(R) CPU           X7560  @ 2.27GHz
Stepping:              6
CPU MHz:               2261.000
BogoMIPS:              4522.00
Hypervisor vendor:     VMware
Virtualization type:   full
L1d cache:             32K
L1i cache:             32K
L2 cache:              256K
L3 cache:              24576K
NUMA node0 CPU(s):     0-7
Flags:                 fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts mmx fxsr sse sse2 ss ht syscall nx rdtscp lm constant_tsc arch_perfmon pebs bts nopl xtopology tsc_reliable nonstop_tsc aperfmperf pni ssse3 cx16 sse4_1 sse4_2 popcnt hypervisor lahf_lm dtherm ida
I'll try to use TF 1.5.
root@05e99fc1ad94:/usr/local/bin# pip uninstall tensorflow
Uninstalling tensorflow-1.10.0:
  Would remove:
    /usr/local/bin/freeze_graph
    /usr/local/bin/saved_model_cli
    /usr/local/bin/tensorboard
    /usr/local/bin/tflite_convert
    /usr/local/bin/toco
    /usr/local/bin/toco_from_protos
    /usr/local/lib/python2.7/dist-packages/tensorflow-1.10.0.dist-info/*
    /usr/local/lib/python2.7/dist-packages/tensorflow/*
Proceed (y/n)? y
  Successfully uninstalled tensorflow-1.10.0
root@05e99fc1ad94:/usr/local/bin# pip install tensorflow==1.5
Collecting tensorflow==1.5
  Downloading https://files.pythonhosted.org/packages/69/6d/09d4fbeedbafbc6768a94901f14ace4153adba4c2e2c6e6f2080f4a5d1a7/tensorflow-1.5.0-cp27-cp27mu-manylinux1_x86_64.whl (44.4MB)
    100% |################################| 44.4MB 8.4kB/s
Requirement already satisfied: protobuf>=3.4.0 in /usr/local/lib/python2.7/dist-packages (from tensorflow==1.5) (3.6.0)
Requirement already satisfied: six>=1.10.0 in /usr/local/lib/python2.7/dist-packages (from tensorflow==1.5) (1.11.0)
Requirement already satisfied: wheel in /usr/local/lib/python2.7/dist-packages (from tensorflow==1.5) (0.31.1)
Requirement already satisfied: absl-py>=0.1.6 in /usr/local/lib/python2.7/dist-packages (from tensorflow==1.5) (0.3.0)
Requirement already satisfied: backports.weakref>=1.0rc1 in /usr/local/lib/python2.7/dist-packages (from tensorflow==1.5) (1.0.post1)
Requirement already satisfied: numpy>=1.12.1 in /usr/local/lib/python2.7/dist-packages (from tensorflow==1.5) (1.14.5)
Collecting tensorflow-tensorboard<1.6.0,>=1.5.0 (from tensorflow==1.5)
  Downloading https://files.pythonhosted.org/packages/cd/ba/d664f7c27c710063b1cdfa0309db8fba98952e3a1ba1991ed98efffe69ed/tensorflow_tensorboard-1.5.1-py2-none-any.whl (3.0MB)
    100% |################################| 3.0MB 2.8MB/s
Requirement already satisfied: enum34>=1.1.6 in /usr/local/lib/python2.7/dist-packages (from tensorflow==1.5) (1.1.6)
Requirement already satisfied: mock>=2.0.0 in /usr/local/lib/python2.7/dist-packages (from tensorflow==1.5) (2.0.0)
Requirement already satisfied: setuptools in /usr/local/lib/python2.7/dist-packages (from protobuf>=3.4.0->tensorflow==1.5) (39.1.0)
Requirement already satisfied: werkzeug>=0.11.10 in /usr/local/lib/python2.7/dist-packages (from tensorflow-tensorboard<1.6.0,>=1.5.0->tensorflow==1.5) (0.14.1)
Requirement already satisfied: futures>=3.1.1; python_version < "3" in /usr/local/lib/python2.7/dist-packages (from tensorflow-tensorboard<1.6.0,>=1.5.0->tensorflow==1.5) (3.2.0)
Requirement already satisfied: markdown>=2.6.8 in /usr/local/lib/python2.7/dist-packages (from tensorflow-tensorboard<1.6.0,>=1.5.0->tensorflow==1.5) (2.6.11)
Collecting html5lib==0.9999999 (from tensorflow-tensorboard<1.6.0,>=1.5.0->tensorflow==1.5)
  Downloading https://files.pythonhosted.org/packages/ae/ae/bcb60402c60932b32dfaf19bb53870b29eda2cd17551ba5639219fb5ebf9/html5lib-0.9999999.tar.gz (889kB)
    100% |################################| 890kB 5.0MB/s
Collecting bleach==1.5.0 (from tensorflow-tensorboard<1.6.0,>=1.5.0->tensorflow==1.5)
  Downloading https://files.pythonhosted.org/packages/33/70/86c5fec937ea4964184d4d6c4f0b9551564f821e1c3575907639036d9b90/bleach-1.5.0-py2.py3-none-any.whl
Requirement already satisfied: pbr>=0.11 in /usr/local/lib/python2.7/dist-packages (from mock>=2.0.0->tensorflow==1.5) (4.2.0)
Requirement already satisfied: funcsigs>=1; python_version < "3.3" in /usr/local/lib/python2.7/dist-packages (from mock>=2.0.0->tensorflow==1.5) (1.0.2)
Building wheels for collected packages: html5lib
  Running setup.py bdist_wheel for html5lib ... done
  Stored in directory: /root/.cache/pip/wheels/50/ae/f9/d2b189788efcf61d1ee0e36045476735c838898eef1cad6e29
Successfully built html5lib
magenta 0.3.11 has requirement tensorflow>=1.8.0, but you'll have tensorflow 1.5.0 which is incompatible.
Installing collected packages: html5lib, bleach, tensorflow-tensorboard, tensorflow
  Found existing installation: html5lib 1.0.1
    Uninstalling html5lib-1.0.1:
      Successfully uninstalled html5lib-1.0.1
  Found existing installation: bleach 2.1.3
    Uninstalling bleach-2.1.3:
      Successfully uninstalled bleach-2.1.3
Successfully installed bleach-1.5.0 html5lib-0.9999999 tensorflow-1.5.0 tensorflow-tensorboard-1.5.1
You are using pip version 18.0, however version 19.1.1 is available.
You should consider upgrading via the 'pip install --upgrade pip' command.
I've noticed an error:
root@05e99fc1ad94:/magenta# python
>>> import re
>>> import sys
Traceback (most recent call last):
  File "<stdin>", line 1, in <module>
  File "magenta/__init__.py", line 33, in <module>
    import magenta.music.abc_parser
  File "magenta/music/__init__.py", line 17, in <module>
    from magenta.music.abc_parser import parse_abc_tunebook
  File "magenta/music/abc_parser.py", line 33, in <module>
    from magenta.protobuf import music_pb2
ImportError: No module named protobuf
So, now I need to find Magenta version, which can work with TF 1.5. TF 1.5 was released on Jan 26, 2018 and I.6 was released on Feb 28, 2018. So I should try install Magenta version, which was released around that time. Magenta 0.3.6 was released on Feb 28, 2018 as well. I'll try to install it first:
root@f0f77d90b611:/magenta-data# pip install magenta==0.3.6
Collecting magenta==0.3.6
  Downloading https://files.pythonhosted.org/packages/6a/c7/285fc2338e0cdcf4435d056c8c949be3e123ed2a1e56c321a0b889ebd38b/magenta-0.3.6-py2.py3-none-any.whl (1.0MB)
    100% |################################| 1.0MB 2.7MB/s
Requirement already satisfied: matplotlib>=1.5.3 in /usr/local/lib/python2.7/dist-packages (from magenta==0.3.6) (2.2.2)
Requirement already satisfied: python-rtmidi in /usr/local/lib/python2.7/dist-packages (from magenta==0.3.6) (1.1.1)
Requirement already satisfied: Pillow>=3.4.2 in /usr/local/lib/python2.7/dist-packages (from magenta==0.3.6) (5.2.0)
Requirement already satisfied: wheel in /usr/local/lib/python2.7/dist-packages (from magenta==0.3.6) (0.31.1)
Requirement already satisfied: scipy>=0.18.1 in /usr/local/lib/python2.7/dist-packages (from magenta==0.3.6) (1.1.0)
Requirement already satisfied: numpy>=1.11.0 in /usr/local/lib/python2.7/dist-packages (from magenta==0.3.6) (1.14.5)
Requirement already satisfied: tensorflow>=1.4.0 in /usr/local/lib/python2.7/dist-packages (from magenta==0.3.6) (1.5.0)
Installing collected packages: magenta, joblib
  Found existing installation: joblib 0.11
    Uninstalling joblib-0.11:
      Successfully uninstalled joblib-0.11
Successfully installed joblib-0.13.2 magenta-0.3.6
Let's test it.
root@f0f77d90b611:/magenta-data# python
>>> import re
>>> import sys
It's a good sign! No core dump was detected this time.
Generating music
root@f0f77d90b611:/magenta# melody_rnn_generate   --config=lookback_rnn   --bundle_file=/magenta-models/lookback_rnn.mag   --output_dir=/magenta-data/lookback_rnn/generated   --num_outputs=10   --num_steps=128   --primer_melody="[60]"
2019-05-26 11:30:49.117489: I tensorflow/core/platform/cpu_feature_guard.cc:137] Your CPU supports instructions that this TensorFlow binary was not compiled to use: SSE4.1 SSE4.2
WARNING:tensorflow:The saved meta_graph is possibly from an older release:
'model_variables' collection should be of type 'byte_list', but instead is of type 'node_list'.
INFO:tensorflow:Restoring parameters from /tmp/tmp2GVxTU/model.ckpt
2019-05-26 11:30:49.589955: W tensorflow/core/framework/op_def_util.cc:343] Op TensorArray is deprecated. It will cease to work in GraphDef version 16. Use TensorArrayV3.
2019-05-26 11:30:49.590786: W tensorflow/core/framework/op_def_util.cc:343] Op TensorArraySize is deprecated. It will cease to work in GraphDef version 16. Use TensorArraySizeV3.
2019-05-26 11:30:49.591090: W tensorflow/core/framework/op_def_util.cc:343] Op TensorArrayScatter is deprecated. It will cease to work in GraphDef version 19. Use TensorArrayGradV3.
2019-05-26 11:30:49.591247: W tensorflow/core/framework/op_def_util.cc:343] Op TensorArrayRead is deprecated. It will cease to work in GraphDef version 16. Use TensorArrayReadV3.
2019-05-26 11:30:49.592265: W tensorflow/core/framework/op_def_util.cc:343] Op TensorArrayWrite is deprecated. It will cease to work in GraphDef version 16. Use TensorArrayWriteV3.
2019-05-26 11:30:49.592458: W tensorflow/core/framework/op_def_util.cc:343] Op TensorArrayGather is deprecated. It will cease to work in GraphDef version 16. Use TensorArrayGatherV3.
INFO:tensorflow:Beam search yields sequence with log-likelihood: -79.070923
INFO:tensorflow:Beam search yields sequence with log-likelihood: -35.156246
INFO:tensorflow:Beam search yields sequence with log-likelihood: -58.394318
INFO:tensorflow:Beam search yields sequence with log-likelihood: -75.590439
INFO:tensorflow:Beam search yields sequence with log-likelihood: -38.718128
INFO:tensorflow:Beam search yields sequence with log-likelihood: -110.032028
INFO:tensorflow:Beam search yields sequence with log-likelihood: -115.888031
INFO:tensorflow:Beam search yields sequence with log-likelihood: -142.042130
INFO:tensorflow:Beam search yields sequence with log-likelihood: -123.102356
INFO:tensorflow:Beam search yields sequence with log-likelihood: -143.292236
INFO:tensorflow:Wrote 10 MIDI files to /magenta-data/lookback_rnn/generated
And I can see these generated midi files now:
root@f0f77d90b611:/magenta# ls -la /magenta-data/lookback_rnn/generated
total 48
drwxr-xr-x 2 root root 4096 May 26 11:31 .
drwxr-xr-x 3 root root 4096 May 24 02:09 ..
-rw-r--r-- 1 root root  295 May 26 11:30 2019-05-26_113049_01.mid
-rw-r--r-- 1 root root  168 May 26 11:30 2019-05-26_113049_02.mid
-rw-r--r-- 1 root root  145 May 26 11:30 2019-05-26_113049_03.mid
-rw-r--r-- 1 root root  361 May 26 11:30 2019-05-26_113049_04.mid
-rw-r--r-- 1 root root  230 May 26 11:30 2019-05-26_113049_05.mid
-rw-r--r-- 1 root root  266 May 26 11:30 2019-05-26_113049_06.mid
-rw-r--r-- 1 root root  237 May 26 11:30 2019-05-26_113049_07.mid
-rw-r--r-- 1 root root  519 May 26 11:31 2019-05-26_113049_08.mid
-rw-r--r-- 1 root root  241 May 26 11:31 2019-05-26_113049_09.mid
-rw-r--r-- 1 root root  354 May 26 11:31 2019-05-26_113049_10.mid
And I can play them too (listen to the attached file).
Now I need to generate music using my sensors data.
https://community.element14.com/cfs-file/__key/communityserver-blogs-components-weblogfiles/00-00-00-02-24/2019_2D00_05_2D00_26_5F00_113049_5F00_01.mid
