Rocking Raspberry Pi
  • Rocking Raspberry Pi
Blog Hacking Pi's SSH under Windows
  • Date Created: 28 Feb 2014 9:29 AM Date Created
  • Views 705 views
  • rocking_pi
e14 Contributor
e14 Contributor
28 Feb 2014
This Article focuses on how to Remote control your Raspberry Pi's SSH using Windows. That means if you don't have an LCD, you can just connect your computer with your Pi.
To achieve this you'll require a ROUTER and a LAN wire(Ethernet Wire), Putty, Advanced IP Scanner.
Downloads:
1)Putty: http://www.putty.org/
2) Advanced IP Scanner: Advanced IP Scanner - Free, fast and easy-to-use network scanner
Step1: Make sure your ssh is enabled on Pi. (This might require a connection with LCD for very first time).
Step 2: Connect your Computer to the Router & your Pi to the Router.(Using LAN Wire)
Blue Wire Connects Pi to Router.
White Wire Connects Computer to Router.(You can even connect them in a wireless manner.)
Step 3: Scan Devices using Advanced IP Scanner and note down the IP of Pi.
Step 4: Start Putty enter the IP of Pi. (Login as Pi, Password: Raspberry)
Login As: pi
pasword: raspberry
Cheers, you have successfully connected your Pi to your computer.
