Rocking Raspberry Pi
  • Rocking Raspberry Pi
Blog Raspberry Pi and Karaoke Machine (Wolfson Pi Use and its Limitation)
  • Author Author: babusingh9211
  • Date Created: 18 Apr 2014 6:54 PM Date Created
  • Views 2654 views
  • Comments 6 comments
  • wolfson_pi
  • rockingraspberrypi
  • raspberrypi
  • rocking_pi
babusingh9211
babusingh9211
18 Apr 2014
Hello everyone,
This week I’ll post to how to use Wolfson Pi and some limitation that I found in the Wolfson Pi while in use.
As previously said I used the technique explained by Ragnar Jensen. So I have attached the “use_case_script” folder it contains the script which helps in selecting your favourite choice of input and output device.
I have attached the use_case_script folder as archive in the post. Download and extract it in your /home/pi/ .
Now the next step is to select your choice of audio input and output device among the available input and output device.
In my case I have selected the Headset as output device and DMIC as Input for that I open the terminal and enter the following commands
cd ~/use_case_script
./Playback_to_Headset.sh
./Record_from_DMIC.sh
This will select your Headset device as output device and DMIC as your Input device you can also use Headset as input device as well. Or you can experiment with other input and output devices.
To record sound from the DMIC enter the following in terminal
arecord -t wav -d 20 -r 44100 -f dat test.wav
This will record audio with sample rate of 44100 Hz. I don’t know why wolfson pi don’t record 8000Hz or 16000Hz sample rate audio format. And also it doesn’t support 8- bit sample format.
To test the recorded sound file test.wav enter the following in terminal.
aplay test.wav
Other than this I install audacity to experiment with the audio features in the raspberry pi and wolfson pi.
To install audacity enter the following in terminal
sudo apt-get install audacity
Here is screenshot of audacity application which I have installed in my Raspberry Pi. Also you can see the stereo recoreded audio in the screenshot.
But If talking about the limitation according to me when using Wolfson Pi or which I have faced
  1. Unable to record 8000Hz/16000Hz sample rate format audio.
  2. Unable to record 8-Bit audio format.
  3. Unable to run 2 or more sound application using wolfson pi at the same time. (So definitely when I use it in karaoke either I hear music or I can loop back my voice).
    Getting error resource or device busy when using 2 sound instances at same time.
  4. And lastly it occupies your GPIO port so that you can unable to connect other devices with it.
If you have any problem and query regarding this don’t hesitate to ask I’ll try my best to answer it. If you have any suggestion’ please comment below.
Regards,
Sumit Rai
use_case_scripts.zip
    e14 Contributor over 12 years ago +1
    Hi! I don’t know why wolfson pi don’t record 8000Hz or 16000Hz sample rate audio format Those limitations crept in by mistake. This post explains: Re: PJSIP/PJSUA with Wolfson audio card Unable…
    e14 Contributor over 12 years ago in reply to babusingh9211 +1
    It seems that if you copy the text from the "view plain" box, extra characters are inserted when you paste it into your editor. I just tested that and I get the exact same errors as you do. Try with the…
  • babusingh9211
    babusingh9211 over 12 years ago in reply to e14 Contributor
    Hi Ragnar,
    You rocked again  image
    Thanks alot, everything is now working.
    ~Sumit Rai
    Try with the "expand source" and copy the text from there.
    Ragnar
  • babusingh9211
    Hi,
    I am getting error
    ALSA lib conf.c:1686:(snd_config_load1) _toplevel_:18:1:Unexpected char
    ALSA lib conf.c:3406:(config_file_open) /home/pi/.asoundrc may be old or corrupted: consider to remove or fix it
    Also I have installed the libasound2-plugins.
    Any other suggestion.
    ~ Sumit Rai
  • mmohit00007
    mmohit00007 over 12 years ago in reply to e14 Contributor
    i proud on u buddy
