Rocking Raspberry Pi
  • Rocking Raspberry Pi
Blog Remote accessing your RaspBMC
  • Author Author: bharatrai888
  • Date Created: 15 Mar 2014 6:20 PM Date Created
  • Views 610 views
  • rockingraspberrypi
  • raspberrypi
  • rocking_pi
bharatrai888
bharatrai888
15 Mar 2014
Hey Friend,
In last post I write about how I control the RaspBMC using TV remote. Another method is to control the RaspBMC over internet.
Well controlling the RaspBMC over internet is so easy. All you need to connect it with the LAN. You can connect it with using Ethernet Cable or using Wi-Pi.
For connecting Raspberry Pi with the LAN, just plug Ethernet cable to the Raspberry Pi. Or connect it using Wi-Pi.
For connecting with the Wi-Pi
  1. Go to program -> RaspBMC setting -> Ok
  2. In network configuration Tab
    Select Network mode to Wireless Network
  3. Go below
    Select Scan Networks and select your broadcasted SSID.
  4. Select Wi-Fi Security type
    In mine case it is WPA/WPA2
  5. Enter your Wi-Fi security key in Wi-Fi key
  6. Press OK from below
Steps to enable the remote access via HTTP
  1. Go to System -> Settings -> Services -> Webserver
  2. Select Allow control of XBMC via HTTP
    Enter your desired port number. Make sure the port is not in use by any other application.
  3. Now you can enter the http://Local-IP:port in your PC browser or in your device connected to LAN.image
  4. You see the Remote control Panel in the browser window. You can control the RaspBMC using that.
  Step to enable Samba Server and VNC server
  1. Go to Program -> RaspBMC setting -> Ok
  2. In system Configuration Tab go below
    Enable Samba Server and VNC server
  3. For accessing the Samba Server. In windows go to start-> run -> type \\your-local-IP and press enter. image
  4. Enter User: Pi and password: raspberry . By using Samba server you can access files of raspberry directly with the computerimage
  5. For accessing the VNC server download VNC viewer from http://www.realvnc.com/download/viewer/
  6. Install vncviewer and open it.
  7. Enter your local-IP:5900 and click on connect
    Fullscreen contentimage_30492.html Download
    <html><head><title>Jive SBS</title></head>
    <body><font face="arial,helvetica,sans-serif">
    <b>Error</b><br><font size="-1">
    An general error occurred while processing your request.
    </font></font></body></html>
  8. Now you can see the see the display and control it over internet.
    Fullscreen contentimage_30493.html Download
This is all I have done with that till now. Promising experiment and write about that.
