Rocking Raspberry Pi
  • Rocking Raspberry Pi
Forum Did any one tried playing videos on VlC media player ???
  • Subscribers 4 subscribers
  • Views 1647 views
  • wolfson_pi
  • rockingraspberrypi
  • raspberrypi
  • wolfson_microelectronics
saurocksall
saurocksall over 12 years ago
Hi fellow contestants,
Have any one of you tried playing video files VLC media player, I tried the video was very laggy, it was only a 360p video,
the other thing is that Wolfson Audio card doesn't work smoothly, and raspberry pi hangs form time to time, i did some research and found that Wolfson Audio card requires a class 6 or higher memory card, the one provided to us was a class 4 card.
And is there any way to get the Wolfson audio card working with RaspBMC, Because playing media content on Raspbian is really not that easy as very less time is left and there is almost no support, documentation for the Wolfson Audio card so it took me time to find out that it requires a class 6 or higher card, what type of card are you guys using ??
There Is also a over heating problem with my raspberry pi  are you also facing something like this ??
    0 shabaz over 12 years ago
    (Just replied to your other post - think perhaps VLC is not hardware accelerated, see here for some info:
    http://intensecode.blogspot.co.uk/2013/10/tutorial-vlc-with-hardware-acceleration.html
    For now you could try omxplayer, see if that works (agreed it is not the same, no idea if omxplayer can do streaming).
  • rohitrangwani
    0 rohitrangwani over 12 years ago
    I am facing some similar problems with wolfson card.I dont think its compulsory to use class 6 or higher sd card.(this is only required for high quality audio).
    But the problem is the instability of Raspberry Pi as you mentioned.
    And as far as Vlc is concerned you can opt for other players as vlc is not hardware accelerated.
  • saurocksall
    0 saurocksall over 12 years ago in reply to rohitrangwani
    Hi Rohit,
    Are you also facing over heating issue when Wolfson card is attached with raspberry pi ??
    Is your Pi also hanging and freezing from time to time ??
    and what player are you using and is it lag free ?? and does it plays videos ??
  • rohitrangwani
    0 rohitrangwani over 12 years ago in reply to saurocksall
    Hi Saurabh,
    Yes,my Pi with Wolfson card also freezes ,sometimes display to rca connected screen goes out after some time,usb devices stops working leaving only the option to go for hard reboot.
    But sometimes it works fine.
    You can use mpg player (mpg123) or mplayer.Both of these do play videos.
    0 shabaz over 12 years ago in reply to rohitrangwani
    Not sure if those are h/w accelerated but omxplayer definitely is.
    I still suspect PSU or the USB cable connected to the PSU issues, was this a power supply with USB cable from Element14, or your own? If it is your own, is it from a smartphone or from a non-smartphone? Older PSUs for smaller phones will not have the power to support the combination possibly.
  • saurocksall
    0 saurocksall over 12 years ago in reply to shabaz
    Its a Nokia charger 5 Volts , 1300 ma....
