Save The Bees Design Challenge
  • Save The Bees Design Challenge
Blog Bee Healthy - Blog 2: Hardware Development - Solar Power Supply
Join Save The Bees Design Challenge to participate - click to join for free!
  • Author Author: ralphjy
  • Date Created: 30 Jan 2023 4:51 AM Date Created
  • Views 2163 views
  • Likes 12 likes
  • Comments 9 comments
  • save the bees
  • savethebeesch
  • nicla vision
  • solar power
  • nicla sense me
  • mkr wan 1310
ralphjy
ralphjy
30 Jan 2023
Still waiting for my challenger hardware kit - haven't seen a shipping notification yet, so I thought I'd work on the solar power supply for the project.  I am building it using a surplus solar panel and a USB power bank that I have available in my parts stash.
The solar panel is rated at 5.5VDC @ 360mA and it has a standard USB A power port.  The power bank is rated at 2200mAh and has a microUSB charge input and a standard USB A output.  So this basically involves mechanically assembling the parts and connecting cables.
I am going to connect the power bank to the microUSB input of the MKR WAN 1310 and use the 5V output header to supply power to the two Nicla boards.
I printed a clip to hold the power bank to the back of the solar panel.
And printed a Go Pro mount adapter since I have a lot of Go Pro mounting hardware.
Here is the front, side, and rear views on a tripod.  The Go Pro mount allows orienting the solar panel.
  • FollowTheWizard
    FollowTheWizard over 3 years ago
    Interesting, I think we will be working with batteries for a first start, but this definitely would help with long term recordings. Great start Slight smile
  • ralphjy
    ralphjy over 3 years ago in reply to DAB
    I’ll run some tests with full sun and partial sun (cloudy), but this setup is oversized for the use case.  Partly because the use case is for spring and summer and I’m doing the development in the winter when there is a lot less solar energy.  Also, the use case is for LoRa and possibly BLE, but in development I will be using WiFi to observe the Nicla Vision results.
    I’ll also try to get some power consumption data when the project is complete.
    beacon_dave over 3 years ago in reply to DAB
    I recall that dougw  did some excellent work in this area a while back with his solar charged super capacitor project:
    /challenges-projects/design-challenges/just-encase/b/blog/posts/just-encase-solar-super-capacitor---project-outline---blog-2
    DAB over 3 years ago
    Nice build.
    Are you going to run some tests to see how much power you can get during a typical day?
  • kmikemoo
    kmikemoo over 3 years ago
    Really nice job on the bracket!  Good choice on the 2200mAh power bank.  None of my 2200's have auto-off - which all of my larger ones do.  Again, good choice.
