Sci Fi Your Pi
  • Sci Fi Your Pi
Sci Fi Your Pi
Blog Knight Rider
  • Author Author: scrpn17w
  • Date Created: 21 Apr 2015 2:53 PM Date Created
  • Views 2105 views
  • Comments 20 comments
  • kitt
  • knight_industries
  • knight_rider
  • sci_fi_your_pi
  • kitt_car
Knight Rider
scrpn17w
scrpn17w
21 Apr 2015
This is my build thread of turning my 1999 Honda Prelude into an emulation of KITT (Knight Industries Two Thousand) from the TV series "Knight Rider". There is going to be a lot of buttons, switches and various indicator lights. I'll add a small screen in the car for both interfacing with the Pi and displaying various data/Images/Videos. Then of course there are the 3 most recognizable traits of the car: The LED "scanner" on the front of the car, the unmistakable voice from the "AI" of the car, and the LED "visualizer" of the cars AI system. Being that I won't be able to make this quite as awe inspiring as the actual KITT and the car I'm using was made in 1999 I'm going to call it the K.I.N.N. (Knight Industries Nineteen Ninety-nine).
  • ipv1
    ipv1 over 11 years ago +2
    Good Job! You might also wanna google "larson scanner" to cut down costs. I did that for my bicycle when I was a kid . A 555 and a 4017 can do wonders I tell ya. All the best! Cheers, IP
  • scrpn17w
    scrpn17w over 11 years ago +2
    After some Google image searching and not coming up with a suitable background to use for KITT's screen I decided to make my own. I found the highest quality "Knight Industries" logo that I could, re-sized…
  • scrpn17w
    I did some digging around yesterday and came upon a project I started a few years ago. It started life as an old joystick for a windows 95 PC. I bought it as a yard sale for a couple dollars and immediately…
  • scrpn17w
    scrpn17w over 10 years ago
    This is the code for the Raspberry Pi that I used.
    import os
    import time
    from time import sleep
    import RPi.GPIO as GPIO
    GPIO.setmode(GPIO.BCM)
    GPIO.setwarnings(False)
    GPIO.setup(23, GPIO.IN, GPIO.PUD_UP)
    GPIO.setup(17, GPIO.OUT)
    GPIO.setup(18, GPIO.IN, GPIO.PUD_UP)
    GPIO.setup(22, GPIO.IN, GPIO.PUD_UP)
    GPIO.setup(27, GPIO.OUT)
    GPIO.setup(24, GPIO.IN, GPIO.PUD_UP)
    GPIO.setup(25, GPIO.OUT)
    scanner = 4
    scan_switch = 15
    GPIO.setup(scanner, GPIO.OUT)
    GPIO.setup(scan_switch, GPIO.IN, GPIO.PUD_UP)
    while True:
    if GPIO.input(scan_switch) == False:
    GPIO.output(scanner, 1)
    else:
    GPIO.output(scanner, 0)
    if (GPIO.input(18) == False):
    GPIO.output(17, 1)
    os.system('mpg123 -q allgo.mp3 &')
    print("All systems go")
    sleep(1)
    GPIO.output(17, 0)
    if (GPIO.input(22) == False):
    GPIO.output(27, 1)
    os.system('mpg123 -q onway.mp3 &')
    print("I'm on my way")
    sleep(1)
    GPIO.output(27, 0)
    if (GPIO.input(24) == False):
    GPIO.output(25, 1)
    os.system('mpg123 -q amuse.mp3 &')
    print("I'm not amused")
    sleep(1)
    GPIO.output(25, 0)
    if (GPIO.input(23) == False):
    os.system('mpg123 -q donttouch.mp3 &')
    print("Something tells me you shouldn't touch turbo-boost")
    sleep(0.1);
    GPIO.cleanup()
  • scrpn17w
    import os
    import time
    scanner = 4
    scan_switch = 15
    while True:
    else:
    GPIO.output(17, 1)
    sleep(1)
    GPIO.output(17, 0)
    GPIO.output(27, 1)
    sleep(1)
    GPIO.output(27, 0)
    GPIO.output(25, 1)
    sleep(1)
    GPIO.output(25, 0)
    sleep(0.1);
    GPIO.cleanup()
