Sci Fi Your Pi
  • Sci Fi Your Pi
Sci Fi Your Pi
Blog Meditech: Battery test
  • Date Created: 18 May 2015 3:58 PM Date Created
  • Views 1440 views
  • Comments 13 comments
  • meditech_project
  • battery_test
  • pi_camera
  • scifi_your_pi
  • raspberry-pi
  • piface_dispaly2
  • battery_power
  • powering
balearicdynamics
balearicdynamics
18 May 2015
After a full-discharge the battery used for testing has been recharged with the simple circuit mentioned in the post Powering the camera probe for few hours to test if the charging circuit, experimental and very simple, may have problems .
Test conditionsimage
  • 7,5 Vcc / 1500 mA LiIon rechargeable battery
  • Full charge done (about 3 hours) with the LM350 based battery charger
  • Power regulator based on LM7805
  • Raspberry PI B+ with camera running continuously with the frame capture program.
  • Frames written on a NFS remote mount to have the WiFi connection always working
  • PiFace Display2 showing a continuously updated message (the system status test) and backlight enabled
  • The entire system has been packed with cardboard and exposed to almost hot sunlight
The duration time has been calculated from the power-on until one of the components has not presented problems due to the low power.
The entire system worked continuously for 63 minutes then camera continued to stream data but the LCD display backlight gone off and the Raspberry PI power led (the red one) disappeared.
The PI temperature shown on the display never raised more than 43 C
  • screamingtiger
    screamingtiger over 11 years ago +2
    I hereby propose we have an element14/sci fi your pi official get together at Enrico's house.
  • crimier
    crimier over 11 years ago +1
    Hi! It's nice to see your progress =) But I have to note that you shouldn't use a linear DC-DC (7805) for this purpose due to its inefficiency, as well as current limit. Use a switching regulator instead…
    e14 Contributor over 11 years ago in reply to balearicdynamics +1
    Show off!! Who needs sunshine when you've got the glorious thunder and lightening like we've got here right now.. giving me goosebumps before I go on set
  • screamingtiger
    Is that where you live?
    balearicdynamics over 11 years ago in reply to screamingtiger
    image Yes, it's just out of the window of the studio.
  • screamingtiger
    screamingtiger over 11 years ago in reply to balearicdynamics
    You live in paradise.  Today it is 40 F (4.44 C) with cold wind.  I need to move.
    I need to get another flight on my quad to test changes and some auto flight but the wind is
    30 mph (48 kph) for last 2 weeks non stop.
    Mhhh... not great good weather I see image
    But this paradise was a choice. Best place to stay calm and work between the sun and the sea. The only great noise two days a week are the gardeners.
    Cheers.
    Cheers.
  • clem57
    clem57 over 11 years ago in reply to balearicdynamics
    Wow, I could get to like a place like yours. I want to visit these islands. How hard to reach from USA?
    image Show off!!
    Who needs sunshine when you've got the glorious thunder and lightening like we've got here right now.. giving me goosebumps before I go on set image
