      • Japan
      • Vietnam
Sci Fi Your Pi
  • Sci Fi Your Pi
Sci Fi Your Pi
Blog Meditech: Bitscope adoption
  • Date Created: 25 Apr 2015 9:14 AM Date Created
  • Views 881 views
  • Comments 8 comments
  • meditech_project
  • signal
  • design_challenge
  • data-logging
  • monitoring
  • acquisition
  • raspberry-pi
  • probe
  • bitscope_micro
  • sci_fi_your_pi
  • ecg
  • blood_pressure
balearicdynamics
balearicdynamics
25 Apr 2015
I am in the phase of distributing the roles to the electronic components and the planning should close today the first timeline for the Sub-projects definition. I plan a series of posts explaining the reasons of the choices of every sub-architecture. These considerations are open to any contribution, suggestions, critics.
After an in-depth check of the features of the Bitscope oscilloscope the facts confirmed what I supposed before reading the documentation.
General considerations
Meditech acquisition unit should be shown as a series of different modules. There is a set of "standard" probes retrieving some of the basic health information based on commercial sensors (i.e. blood pressure, temperature, hearth rate) and a set of more uncommon probes that can be used depending on the needs. These probes (e.g. ECG terminals, just to cite the simplest) should be acquired with a relevant precision.
As a matter of fact the kind of hardware that better fit (almost perfectly) to assolve this task is just the Bitscope, not last for its reasonable price, essential electronic design and very reduced size with a more than acceptable quality of the samplings.
Bitscope flexibility
The flexibility of the tool - that is, the ability to acquire a wide range of different kind of data, digital and analog - can be considered the key factor for the choice.
But the very important aspect is, despite the "natural" role of the hardware, that it is a general purpose data acquisition and analysis tool: for a certain number of probes it is the perfect electronics!
As the next problem arises, the option to control the acquired signals, the problem is solved: first there is the compatibility with the Raspberry PI devices and second there is a full set of APIs to gain the control of the device programming it as the different measuring requires.
To grant the better timing and data resolution, at least in the product initial design and prototyping the less powerful Raspberry PI will be dedicated to control and manage the acquisition trend from the bitscope as an independent subsystem of the architecture.
    balearicdynamics over 10 years ago in reply to Former Member +2
    What my experience teache is that it is not rare that the same thing, saw in a different perspective, can deserve surprising posssibilities
    DAB over 10 years ago +1
    Nice post, Does anyone know if the Bitscope has been upgraded to work with the new RPI 2? DAB
  • Former Member
    Former Member over 10 years ago in reply to balearicdynamics +1
    Exactly.. why reinvent the wheel when you can exploit something else!
    Nice post,
  • crimier
    crimier over 10 years ago in reply to DAB
    It should work, at least I don't see a reason why it shouldn't. I'll test it soon though, I think, and make a post about that.
  • Former Member
    Former Member over 10 years ago in reply to crimier
    Great thinking to use the Bitscope as part of a your device and not a development tool!!
  • Former Member
    What my experience teache is that it is not rare that the same thing, saw in a different perspective, can deserve surprising posssibilities image
  • Former Member
    We are seeing the same point, Lucie!
    As a matter of fact not rarely I see that a too "engineer" view is always the approach to recreate with complexity image
    Working with always a great attention to the costs, so much times the same thing that in an application field is extra-expensive it is a super-cheap spare part in a different field. IMHO, better and elegant equals to simple.
