Sci Fi Your Pi
  • Sci Fi Your Pi
Sci Fi Your Pi
Blog Meditech: Camera probe with PI camera
  • Date Created: 13 Jun 2015 7:35 AM Date Created
  • Views 833 views
  • meditech_project
  • diagnostic_probe
  • piface_cad
  • pi_camera
  • iris_reactivity_test
  • non_invasive_diagnostic
  • raspberry_pi
  • visually_evoked_potentials
  • ws2812b_5050_rgb_led
  • vep
balearicdynamics
balearicdynamics
13 Jun 2015
The external Meditech camera probe, a Raspberry PI unit that can be detached from the main device, is one of the most versatile probes of the system. This unit will host the PI camera to be used for any kind of video / shooting when needed to see and remotely share (also real-time when needed) images of the environment or the patient. Around the camera lens there is a 12 RGB LEDs ring that can provide several functions:
  • White light for simple illuminate small dark areas while shooting or making videos
  • Flashing light for automated iris reactivity test
  • Specific colours to check possible vision diseases
  • Other VEP (Visually Evoked Potentials and reactions) based on coloured lights
Pre-assembly
The following image shows the pre-assembly of the probe.
PiFaceCAD usage
To manage the probe while it is not nearby the main device a small user interface should be built so the PiFaceCAD has been adopted. The question was how to manage the Control and Display device with the micro controller while the light ring should also work at the same time, but the display and controller seems using almost all the PI pins.
Instead, while all the PiFace PI boards works controlled by the SPI the display and control continued woking fine also with the RGB LEDs ring connected to the GPIO bus (PWM pin 18). In this prototype version it has been used the Adafruit neopixel 12 ring but the LED component can be found by several distributors, 100 units per package for few cents.
Next step
The following video shows the test of all the components together (the monitor will not be present in the final version). The next step is to build a box for the probe.
Last but not least...
Thanks for the support to fvan for the great neopixel tutorial and clem57 & Robert Peter Oakes for the PiFaceCAD suggestions.
  • fvan
    fvan over 11 years ago +1
    Glad one of my posts was useful! You're making quite a lot of good progress there
    balearicdynamics over 11 years ago in reply to fvan +1
    Really useful, thanks a lot ! Saved the PDF in my Tech Doc folder Enrico
  • clem57
    clem57 over 11 years ago in reply to balearicdynamics +1
    Glad to help you Enrico Clem
  • fvan
    Glad one of my posts was useful! You're making quite a lot of good progress there image
  • fvan
    Saved the PDF in my Tech Doc folder image
    Enrico
  • clem57
    Clem
