Sci Fi Your Pi
  • Sci Fi Your Pi
Sci Fi Your Pi
Blog Picorder SCRIPT
  • Author Author: saturnv
  • Date Created: 28 Aug 2015 11:40 PM Date Created
  • Views 1533 views
  • star_trek
  • handheld_sensor
  • sci_fi_your_pi
  • tricorder
Picorder SCRIPT
saturnv
saturnv
28 Aug 2015
Picorder SCRIPT
# 5 Feb 2022
This is the picorder Python script I wrote for the "SciFi your Pi" challenge in 2015
Now 6 years later, I still retain the Picorder along with other projects I've developed and worked on over the years.
Being recognized as one of the "Final Four" in the international contest, let alone being selected
as a contestant is a great honor and privelege. Since then I've used the Raspberry Pi microcumper
for many of my home projects including and internet radio, surveilliance camera,
touch screen pc browser, and more. Thanks again Element14 for the opportunity.
#!/usr/bin/env python
## Michael Hahn - Final Version 8-27-2015
## Sci_Fi_Your_Pi element14 contestant.
## The Picorder: A Star Trek style Tricorder
## Flame Sensor_Temperature_Humidity_Motion_Distance Sensing routine
import os
import sys
import RPi.GPIO as GPIO
import time
import Adafruit_DHT
from time import sleep
GPIO.setmode(GPIO.BCM)
GPIO.setwarnings(False)
GPIO.setup(13, GPIO.IN)# Flame detector
GPIO.setup(17, GPIO.IN) # PIR motion detector
temp = Adafruit_DHT.DHT11
pin = 4
os.system('omxplayer --no-osd -o local Picordersound.mp3 &')
##### Flame Detection SENSOR
if (GPIO.input(13)):
    print
    print
    print("Flame detected, take ACTION")
    os.system('omxplayer --no-osd -o local Autodefense.mp3 &')
    print
    print
else:
    print
    print
    print("No Flame detected, safe to proceed")
    print
    print
##### DISTANCE MEASURING SENSOR
TRIG=26
ECHO=6
GPIO.setup(TRIG,GPIO.OUT)
GPIO.setup(ECHO,GPIO.IN)
print "Waiting For Sensor To Settle"
time.sleep(1)
GPIO.output(TRIG, True)
time.sleep(0.00001)
GPIO.output(TRIG, False)
print
print "Distance Measurement In Progress"
print
pulse_start = time.time()
time.sleep(0.00005)
pulse_end = time.time()
os.system('omxplayer --no-osd -o local Queue.mp3 &')
pulse_duration = pulse_end - pulse_start
distance = pulse_duration * 17150
distance = round(distance, 5)
print
print "Distance:",distance,"cm"
##print " Distance :%5.1f cm" % distance
print
print
humidity, temperature = Adafruit_DHT.read_retry(temp, pin)
if humidity is not None and temperature is not None:
    print
    print 'Temp={0:0.1f}*C  Humidity={1:0.1f}%'.format(temperature, humidity)
    print
else:
    print
    print 'Failed to obtain reading. SCANNING!'
    os.system('omxplayer --no-osd -o local nosignal.mp3 &')
    print
    sleep(1);
###### PIR MOTION SENSOR
input = GPIO.input(17)
if (GPIO.input(17) == True ):
        print
        print "DANGER - DANGER - MOTION has been detected"
  os.system('omxplayer --no-osd -o local IntruderAlert.mp3 ')
        print
else:
        print
        print "SCANNING AREA for signs of MOTION"
        print
  sleep(1);
def restart_program():
    """Restarts the current program.
    Note: this function does not return. Any cleanup action (like
    saving data) must be done before calling this function."""
    python = sys.executable
    os.execl(python, python, * sys.argv)
if __name__ == "__main__":
    answer = "y" #raw_input("Do you want to restart this program ? ")
    if answer.lower().strip() in "y yes".split():
        restart_program()
  • clem57
    clem57 over 11 years ago +1
    Very clean well written code. Thanks. C
    balearicdynamics over 11 years ago +1
    I agree with Clem, very well and clean code. Enrico
  • saturnv
    saturnv over 11 years ago in reply to balearicdynamics +1
    Echoing my comment on Clem's comment. Thank you very much Enrico. Your comment is greatly appreciated. Gives confidence to continue with projects, challenges and learning and developing code. Now a brief…
  • saturnv
    Echoing my comment on Clem's comment. Thank you very much Enrico. Your comment is greatly appreciated. Gives confidence to continue with projects, challenges and learning and developing code. Now a brief regeneration period, and then back to the drawing board with new projects to conquer!
  • saturnv
    saturnv over 11 years ago in reply to clem57
    Thank you very much Clem. Your comment is greatly appreciated. Gives confidence to continue with projects, challenges and learning and developing code.
    Enrico
  • clem57
    Thanks.
    C
