Sci Fi Your Pi
  • Sci Fi Your Pi
Sci Fi Your Pi
Blog PizzaPi: The Mosquitto struggle
  • Author Author: dmrobotix
  • Date Created: 10 Jun 2015 5:41 AM Date Created
  • Views 1711 views
  • Comments 16 comments
  • design_challenge
  • pizza_pi
  • sci_fi_your_pi
dmrobotix
dmrobotix
10 Jun 2015
Hello, everyone!
Well, I've been struggling to get Mosquitto to play friendly with websockets. Has anyone else tried running Mosquitto with websockets enabled? I posted the following on someone's blog about running the MQTT server on a raspberry pi but it is still "awaiting moderation" so I'm reaching out to this wonderful community for some help! Otherwise, if I can't get it working, I'm just going to stick to the tried-and-true mqtt protocol and pass a text file to lighthttpd. Always have to have a back up plan!
I’m running mosquitto 1.4 on a raspberry pi. mosquitto is able to open a websockets port on 9001 and listen. I can connect fine but I get the socket error message: "Socket error on client , disconnecting." I’m using an example javascript Paho code found here:
https://www.eclipse.org/paho/clients/js/
Here is my mosquitto.conf:
allow_anonymous true
autosave_interval 1800
persistence true
persistence_file m2.db
persistence_location /var/lib/mosquitto/
#connection_messages true
#log_timestamp true
#log_type all
#log_dest file /var/log/mosquitto/mosquitto.log
listener 1883
listener 9001 127.0.0.1
protocol websockets
So, any thoughts?
In other news, I made this wonderful discovery. Film heating elements. I'm thinking of adding one to the delivery bag that I'm modifying so that it can maintain a decent internal temperature to keep the pizza(s) warm during travel. The idea is that the heating element can be monitored via the temperature sensor and (hopefully) adjusted via the RPis built into the bag.
The film heating elements vary in voltage, I've seen a lot of 12 and 24V ones but I did find a version on Sparkfun that would be ideal for the project and it warms up to approximately 65 degrees Celsius (150 degrees F). With some decent foam padding to insulate it, it could do a decent job of keeping things cozy.
  • dmrobotix
    dmrobotix over 10 years ago in reply to mcb1 +2
    Hm...interesting thought. I don't know if I like the idea of people handling hot tiles, plus they might make the bag too heavy. Still, I appreciate the suggestions!!!
    DAB over 10 years ago +1
    You might want to see if the cardboard box insulates the Pizza from your heater. You might need to have a little insert so that the heating element sits inside the box during transport. DAB
    mcb1 over 10 years ago in reply to balearicdynamics +1
    Why an inverter? Simply because most are 230 (or 110) volts and relatively low wattage. They are completely waterproof and safe ... Mark
    mcb1 over 10 years ago in reply to DAB
    The deliveries I've seen use a foil lined bag to put the whole thing in to keep it warm..
    You might be better off just using a pet warmer and an inverter off the car.
    balearicdynamics over 10 years ago in reply to mcb1
    Why an inverster?
    Why an inverter?
    Oh, silly me, I have not considered this option image !
    Thanks. Enrico
  • dmrobotix
    Hey Mark,
    Do you mean something like this?
    http://www.dog.com/item/kh-mfg-self-warming-gray-dog-crate-pad/494958/
    Thanks everyone for the great feedback. Still trying to figure out the websockets issue.
