Sci Fi Your Pi
  • Sci Fi Your Pi
Sci Fi Your Pi
Blog QuadCOP:  Hover and Loiter Test
  • Author Author: screamingtiger
  • Date Created: 28 Aug 2015 5:13 PM Date Created
  • Views 2795 views
  • Comments 8 comments
  • quadcop_project
  • design_challenge
  • star_wars
  • sci_fi_your_pi
  • nervous
screamingtiger
screamingtiger
28 Aug 2015
Previous Posts Here:
http://www.element14.com/community/community/design-challenges/sci-fi-your-pi/blog/authors/screamingtiger?ICID=DCH-SciFiPi-challengers
I was very nervous.  I turned the loiter on for just a second and it held then started dropping, the ground sensor caught it.
Because my controls are being passed through the chipkit pi, there is some  resolution lost so its a bit touchy for a hover..
A few messy pre flight pics, and the video.  I am going out to get a better flight and test some more of the functionality.  Today is a busy day.
Messy but secure.  Covered up by the top head so who cares!
Ping sensors.  Only 2 of 4 installed.
I need a haircut.  And to comb my hair.  And a bath.  This project has taken control of my life!
I have to go fly more, no time to waste!  The last few seconds of the vid is the loiter, I yelled STOP because I thought it would crash into the ground.  It got very close but the triggers worked and it detected ground!  WHEW
BTW the head is moving by itself as intended, I need to fix up the moving algorithm, its pretty plain.
Edit:  A couple notes of how my version of loiter works.  Typically loiter attempt to maintain heading, and to maintain a specific GPS coordinate all within some certain thresholds.
If a quad needs to move backwards, it can move backwards.  But not my quad (yet).  It will do a 180 degree turn and move forwards.  Currently, all special corrections are done with forward movements.  I gave my quad an advantage during testing in that I put the nose into the wind, meaning it may not have to turn around.
So its like a game of Asteroids where as the ship goes through the center of the pull, it does a 180 to face it.  The nose always points into the center of the field.
This is just to make testing easier.  Just like the heading wont do a 350 degree left rotation instead of a 10 degree right rotation, the same efficiency algorithm can be used to move without changing heading at all.
    DAB over 11 years ago +1
    Not bad for your first flight. It looks like the hover mode is a little jerky, you might need to add some smoothing algorithms. DAB
    Jan Cumps over 11 years ago +1
    You made it. Congratulations!
  • fvan
    fvan over 11 years ago +1
    Nice!
  • clem57
    clem57 over 11 years ago
    Nice work Joey. Giving you a pat on the back.
    C
  • clem57
    C
