Sci Fi Your Pi
  • Sci Fi Your Pi
Sci Fi Your Pi
Blog Quick Update on the QuadCop and the ChipKit Pi
  • Author Author: screamingtiger
  • Date Created: 1 May 2015 4:22 AM Date Created
  • Views 517 views
  • quadcop_project
  • design_challenge
  • chipkit_pi
  • sci_fi_your_pi
screamingtiger
screamingtiger
1 May 2015
Other posts on my project:
http://www.element14.com/community/tags#/?tags=quadcop_project
I am working on a real update for my project.  I have several parts connected up and nearly 1000 lines of C code written for my arduino and my Raspberry Pi2.  I have some things to demonstrate and some explanations to do.
I decided to take a tangent and work with the ChipKit Pi.  I remember a few years back I wanted a Chip Kit UNO because it was a 32 bit processor that is much faster than the AVR used in the Arduino, however I never got around to it.  I didn't recognize what Element14 had sent me until I looked at it closer!  I am very excited to own one of these.
I have been testing some code on an Arduino nano328 to read my radio's PWM signals and communicate via I2C to my Raspberry Pi2.  Things are working great so I spent some time seeing if I can get the same code to run on the ChipKit.  The code compiled with minimal changes.  I used the MPIDE on the Raspberry pi to compile it.
As a quick test, I ran a simple speed test on all 3 parts involved and here is a video outlining my results.  This is the FIRST video blog I have ever done so bare with me, they will get more polished over time.  Watch the video and read some more comments below.  I kept wanting to call the ChipKit Pi the ChipKit UNO so you will hear me pause every time I say it.
https://www.youtube.com/watch?v=4tPfn6qDRAs&feature=youtu.be
To summarize:
ChipKit Pi:  98ms
Arduino Nano: 4350ms
Raspberry Pi 2: 15ms
Notes
Phantom I2C objects
Serial pins are different for uploading sketches and for viewing output from Serial.print statements.
Wire.read() is Wire.receive() in the ChipKit version.  I commented the wire parts out int eh CHipKit Pi code below.
I am not certain the MPIDE is turning on compiler optimizations.  Will research.
Speed increase of the ChipKit Pi:  44.3 times faster.
The Raspberry Pi2 is 6.5 timers faster than the ChipKit pi, and 290 times faster than the Arduino.
Keep in mind this is just a purely simple processing test and ignore I/O  and other functionality.
PS:  QuadCOP parts get tomorrow, the FUN stuff including all the motors and the frame!  Should be able to do a test flight (manual, no pi etc.) this weekend.
Raspberry Pi Code (use time command to get results):
#include <stdio.h>
int main()
        int a;
        int b;
        b = 1;
        int l1 = 100;
        int l2 = 10000000;
        for(int i=0;i<100;i++)
        for(a = 0;a <=3000;a++)
                b = b +  a;
                b = b * 2;
                b = b % 1657;
        printf("Result: %d\n",b);
return 0;
Arduino Code: (spits out information on serial)
#include <Wire.h>
int lastAnswer;
void receiveEvent(int howMany)
void requestEvent()
  Wire.write(lastAnswer); // respond with message of 6 bytes
                       // as expected by master
void setup()
        Wire.begin(4);                // join i2c bus with address #4
        Wire.onReceive(receiveEvent); // register event
        Wire.onRequest(requestEvent);
        Serial.begin(9600);
void loop()
        Serial.println("starting test");
        unsigned long ms = millis();
        int a;
        int b;
        b = 1;
        int l1 = 17;
        int l2 = 3000;
                b = b +  a;
                b = b * 2;
                b = b % 1657;
        lastAnswer = b;
        ms = millis() - ms;
        //printf("Result: %d\n",b);
        Serial.println("test completed");
        Serial.print("Answer: ");
        Serial.println(b);
        Serial.print("Time: ");
        Serial.println(ms);
Chip Kit Pit code:
int lastAnswer;
void requestEvent()
  //Wire.write(lastAnswer); // respond with message of 6 bytes
void setup()
        //Wire.begin(4);                // join i2c bus with address #4
        //Wire.onReceive(receiveEvent); // register event
        //Wire.onRequest(requestEvent);
        Serial.begin(9600);
void loop()
        int a;
        int b;
        b = 1;
        int l1 = 17;
        int l2 = 3000;
                b = b +  a;
                b = b * 2;
                b = b % 1657;
        lastAnswer = b;
        ms = millis() - ms;
        Serial.println(b);
        Serial.println(ms);
