Shift it! Warehouse Automation Design Challenge
  • Shift it! Warehouse Automation Design Challenge
Forum soldering eternal wire was giving absurd resistance on RTD temperature sensor
  • News
  • Projects
Join Shift it! Warehouse Automation Design Challenge to participate - click to join for free!
  • Replies 9 replies
  • Subscribers 45 subscribers
  • Views 1128 views
  • design challenge
  • shift it
manojroy123
manojroy123 over 1 year ago
soldering eternal wire was giving absurd resistance on RTD temperature sensor. How to solve it.
  • manojroy123
    manojroy123 over 1 year ago in reply to Jan Cumps +2
    I replaced the wire that was giving higher resistance
  • kmikemoo
    kmikemoo over 1 year ago +1
    Extend both leads by equal lengths. If extended length is quite long, the increased resistance of the wire may be unavoidable. 28AWG has around 21 ohms per 100m. Moving to 24 AWG drops to around 8 ohms…
    shabaz over 1 year ago in reply to manojroy123 +1
    Have you used Ohms law? If you have not, then why not? Have you used an ohmmeter to measure the resistance (and if not, again, why not?). And if you did, why have you not provided this information in…
  • kmikemoo
    0 kmikemoo over 1 year ago
    Extend both leads by equal lengths.  If extended length is quite long, the increased resistance of the wire may be unavoidable.  28AWG has around 21 ohms per 100m.  Moving to 24 AWG drops to around 8 ohms per 100m.  Solid vs stranded can change these values.  If shortening the leads starts to bring the reading back to what you think is reasonable, you have no other option than using the shorter leads.  Ohms Law is Ohms Law.
    Use copper wire.  Dissimilar metals may create a problem.
    Both leads go from source and back to microcontroller with no other connections.  No shared return paths for these sensors.
    Check for cold solder joints.  Also check ground connections.  If using a shared ground bus but only one 28AWG jumper goes from your buss to your microcontroller... there's your problem.
  • manojroy123
    0 manojroy123 over 1 year ago in reply to kmikemoo
    I was getting resistance because of soldering two wires together. How to solve it. I don't have crimping tool for crimping connector.
    0 shabaz over 1 year ago in reply to manojroy123
    Have you used an ohmmeter to measure the resistance (and if not, again, why not?). And if you did, why have you not provided this information in your question?
    Why are your questions always so lacking in detail?
    I'd be interested to see what resistance you're measuring for your setup, and then, when you apply Ohms law, your explanation for how much of a difference you think your setup will make due to the addition of your wire and soldered joints.
  • manojroy123
    0 manojroy123 over 1 year ago in reply to shabaz
    I am looking for best solution not temporary solution. Please help me in it.
  • balajivan1995
    0 balajivan1995 over 1 year ago in reply to manojroy123
    I don't think the red wire is properly soldered. Check for connectivity first.
    If you're convinced you soldered things well, then there's a good chance you've simply got a break in the wire, or those crimped connectors at the wire ends are badly crimped (quite likely if they were purchasd ready-made at very low cost).
  • manojroy123
    Thanks everybody my problem was solved.
    0 Jan Cumps over 1 year ago in reply to manojroy123
    how?
  • manojroy123
    0 manojroy123 over 1 year ago in reply to Jan Cumps
