Sixth Sense Design Challenge
Blog 1) Introduction of our project.
  • Author Author: utkarshsharma
  • Date Created: 19 Dec 2018 11:34 AM Date Created
  • Views 1663 views
  • Likes 10 likes
  • stm nucleo
  • stm-32
  • all-terrain_vehicles
  • stm development boards
  • sixth sense design challenge
utkarshsharma
utkarshsharma
19 Dec 2018
Hello everyone! Without wasting much time for the kit to arrive. Let me first give an introduction to what I do. I am member of Vjti Racing Team, Mumbai which is consist of 32 engineering enthusiast. My task is handling the entire electronic aspect of the car. Here is a photo of our car manufactured previous year -
So the stuffs which I decided to incorporate in this vehicle are:
  1. Speedometer: It will work on the basis of hall effect. Hall effect sensor detects the magnet attached to the flywheel of the shaft. So we would check how time it would take to complete one rotation. Accordingly we would compute the velocity.
  2. Measurement of temperature of the fluid present inside gear box: We would be using waterproof temperature probe DS18B20 (https://www.sparkfun.com/products/11050).
  3. Temperature of CTV belt (https://en.wikipedia.org/wiki/Continuously_variable_transmission) would help us to cool the engine by switching on the fan when required. PTF Series RTD Sensor would be a good choice for this task.
  4. Display board: A display board would be mounter on the dashboard to give meaningful indication to the driver.
  5. GPS module: A GSM + GPS + GPRS module would be used the task of detecting the vehicle in the long stretch. Here is one of the example (http://gpsrf.ru/download/UserManual_TK102B_eng.pdf)of gps module. We are yet to research on it.
  6. Fuel tank measurement: This would be done with the help of capacitance sensor FDC1004 (FDC1004) which would measure the capacitance between petrol. The difference in dielectric of fuel and air would be measured & accordingly fuel amount would be measured.
There are many more things which we would like to incorporate in our vehicle. All these things would be controlled by STM32 development board. Lets see how the things work in coming days.
Thank You.
  • three-phase
    three-phase over 7 years ago +2
    Good introduction to your project, a lot of different things to pull together - good luck with it. Kind regards
  • pikachu05
    pikachu05 over 7 years ago +2
    Nice idea, lot of stuff involved, all the best Neo member.
  • mu.udhay
    mu.udhay over 7 years ago +2
    https://courses.edx.org/courses/course-v1:UTAustinX+UT.RTBN.12.01x+2T2018/course/ this is a free course , it deals with ti based ARM M4 , but it would be helpful for you to work on Nucleo Board as they…
  • mu.udhay
    this is a free course , it deals with ti based ARM M4 , but it would be helpful for you to work on Nucleo Board as they both are ARM cortex M4 based ones.
    If you follow above above course then you should be able to work on your own using the reference Manual which details with the Registers for accessing different Functionalities , clocks , memory maps ...
    You can Simply Use this Technical Reference Manual : HERE
    You can see more References and Example Programs in ST page itself : CLICK HERE
    For Sensor Tile Development Kit : Go Here
    In the Resources Go to User Manual to Read the Necessary details you Need to work and they give you references also , the Craziest Part is Sesortile has STM32L4 based uController means you can work on it just as same as you work on STM32F4 based Nucleo .
    Last But not Least Subscribe to STM channel in youtube , they also give good tutorials.
    If you go stuck , feel free to ask image
    udhay
  • utkarshsharma
    utkarshsharma over 7 years ago
    Could anyone please suggest some tutorials to operate this board ?
  • pikachu05
  • three-phase
    Kind regards
